It sounds like a bad connection somewhere. If your front wheel has been off, and the speedometer cable was reinstalled without due care, that can damage the sender inside the hub. It will cause very odd speedometer behavior. Since you are getting odd temperature behavior, too, it is more likeley that you have a problem in another connector somewhere. You don't have a whole lot of plastic to remove to check it out, so that is the good part! The bad part is that you will probably have to trace all the connectors that attach in any way to your instrument cluster. Make sure the grounds are all connected properly- bad grounding will cause all kinds of bad behavior.
Hope this helps.
Will
