I remember seeing that article but being fortunate enough to have gotten one of the few Daytonas without the typically squishy front ends I left well enough alone, except, (ah there's always that little extra we just have to do), I changed the fork oil to the next heavier grade. With Houston summers being a bit on the tepid side the heavier oil works great.
Back to the question at hand, over on this side of the great pond quite a few folk are using the Racetech valve system with heavier springs on the fronts. Here the whole deal is around 300 to 400U.S., depending on the shop. If nothing else this seems to be one of the better fixes/hop-ups you can do. It will give the front end a much better and positive feeling and eliminate the soft front end syndrome.
Good luck and hope this was of some help with the squishies :wink:
