Geoff, if your electrics are okay then you will need a new switch, those units are sealed and there is not much you can do about it (it is indeed pressure operated).
|You can probably save yourself a few quid by taking the old one to an auto factor rather than buying a Triumph part, AFAIK they are pretty universal.
