The leak is either coming from the cam cover (cheap, easy fix) or the head gasket ( a lot more expensive).
If the leak is originating above the header pipes it is the cam cover gasket. The cover may only need torqueing down.
The best thing to do is clean up the area and then work out exactly where the oil is coming from.
