Motorcycle.com
Old 05-11-2005   #1 (permalink)
I am thinking about trying to use a plastic welder to repair some old fairings that I have. The fairings have only small linear cracks and all the plastic is there. Nothing has broken away. The welder says it only works on specific types of plastics like; Polyurethane, Polypropylene, ABS, Polyethylene, TPO, Nylon, Polycarbonate, FiberFlex. Does anyone know what the fairings an an 02 Daytona are made of?
Old 05-11-2005   #2 (permalink)
Favorite Bike: Very fast 675
Will's Avatar
My TT600 plastic is ABS. I would be very surprised if Triumph used anything else on another model.
For what its worth, sewer pipe cement works on it. It is the black cement that plumbers use on ABS drain pipes- you can get it at a home improvement store. A small can costs about two bucks and is a lifetime supply unless you plan on crashing on a weekly basis!
[ This message was edited by: Will on 2005-05-11 09:37 ]
Will
Old 05-11-2005   #3 (permalink)
I had very good success using Krazy Glue on the side panels and front assembly of a badly crashed TT600. Looks ugly, but works fine for the track! And suprisingly strong.
Because they're fast!
MadMark is offline   Reply With Quote
Old 05-11-2005   #4 (permalink)
I have had luck with a strip of fiberglass/carbon and good quailty super glue. The lower fairing of my daytona was cracked when I got it, have seen the crack on many. Cleaned the inside, strip of glass 1" wide, rubbed in super glue with some wax paper on my finger. Holds very well. Not pretty enough to do on the outside.
We's a turn'n, we's a turn'n
ryan is offline   Reply With Quote
Old 05-14-2005   #5 (permalink)
Good tips thanks alot!!!
Old 05-14-2005   #6 (permalink)
Old 06-16-2005   #7 (permalink)
whistler
My son has welded several fairings with a soldering iron and a strip of same type plastic.Welded the crack together, built it up a bit with a strip of same type plastic ,sanded it,primed it and sprayed it.boom! boom!. Looked good as new. :hammer:
What made You Buy a Triumph? SoCalSprint Biker Hang-Out 243 1 Day Ago 03:13 PM
Why hasn't Triumph made a 1050 Daytona? atvman_400 Daytona Deliberations 26 06-11-2008 11:36 PM
IF TRIUMPH MADE A $20K BIKE, WOULD YOU............ Brooksie Daytona Deliberations 14 11-01-2006 12:06 PM
Once the sale is made, does Triumph care? Mr_Chips Triumph, Models & Dealers 34 01-15-2006 09:19 PM
OC Triumph made me happy bajajoaquin Triumph, Models & Dealers 1 12-29-2004 09:49 PM
