Shapers big project - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
post #31 of 39 (permalink) Old 12-03-2012, 08:17 PM Thread Starter
Main Motorcycle: 1972 Triumph TR6R Tiger
shapers big project
Well I guess I'll just clean up the T120 head and cylinders and put them up for sale, then pay for the proper set to go on the TR6R.
I already have more projects to work on without rigging something that I want to put my backside on and blissfully ride around the county for days on end.
The T120 engine case is damaged so it has no value, but everything in it can be sold off to help get the other one up and running.
Sounds like a plan.
shaper is offline
post #32 of 39 (permalink) Old 12-04-2012, 01:13 AM
TE Lifetime Contributor
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
Originally Posted by shaper View Post
This engine is a T120 with a 9 bolt head. the one I am trying to rebuild is a TR6R with a 8 bolt head. I'm betting I can't use them on my TR6R. So is there a market for trading the pistons, cylinders, and head for a set that I can use? Or can I use any of the items on the TR6R.
Why are you trying to rebuild a '72 engine with an 8-bolt top end?8-bolt stuff is pre-'63.
Keep the 9-bolt barrel and pistons and pushrod tubes to use on the '72.Get a '72 head and rockers.
Sell the 8-bolt stuff that is now becoming rare.
Mr.Pete is offline
post #33 of 39 (permalink) Old 12-04-2012, 09:47 AM Thread Starter
shapers big project
I have been searching for the information you are talking about.
The 8 bolt head and cylinder came off of the 72 tiger 650 engine, JG33xxx. If that isn't the proper items for that year, then someone must have put them on years ago. The #2 engine, a parts engine I have, NG36xxx came with good set of pistons, cylinders, and 9 bolt head. If this is true then all I need to do is swap them from the parts engine onto the engine I am rebuilding, right?
I was looking for replacement items like the ones I pulled off so I can keep it as built originaly.
shaper is offline
post #34 of 39 (permalink) Old 12-04-2012, 10:38 AM Thread Starter
shapers big project
here's is something else to consider.
The The 8 bolt head thatI pulled off is a single carb head. It is also the one with a crack into the valve area. And the cylinders and pistons are 60 over.
The parts motor has a good 9 bolt head and has cylinders and pistons that are standerd size. but it is a two carb head. So which is correct for a 1972 Tiger 650?
shaper is offline
post #35 of 39 (permalink) Old 12-04-2012, 11:11 AM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 2007 Honda Fireblade
Tuning in....this should be fun.
jbenarao is offline
post #36 of 39 (permalink) Old 12-04-2012, 01:24 PM
Main Motorcycle: 1971 Bonneville
therabbithole's Avatar
Other Motorcycle: 1962 T100SS
Extra Motorcycle: 1970 CL350
How 'original' do you want it? The TR6 would originally have had only one carb but lots of folks have swapped the TR6 heads onto T120 engines and vice versa (purportedly for simplicity and performance, respectively), so it seems safe to assume you'd be fine using whatever head you've got. The cams were different, though I don't know by how much and doubt it would be much of a problem as long as you're careful with timing, carb setup, etc.
Also: are you sure it's a Bonneville head? I had the impression that the TR6 single-carb manifold would bolt right up on the T120 head, meaning the heads themselves probably look pretty close by themselves...?
therabbithole is offline
post #37 of 39 (permalink) Old 12-04-2012, 01:46 PM Thread Starter
shapers big project
Yes, they pretty much look the same except the 120 head has 9 bolts and two carbs.
The TR6 head has 8 bolts and and only one carb.
Keep in mind the above is as I pulled them off the two different engines.
I'll look for part numbers on both later today and will post my findings.
shaper is offline
post #38 of 39 (permalink) Old 12-05-2012, 07:30 AM
The red one looks like it has a single carb head,but no manifold.The rocker boxes won't be right for the '72 frame and you'll need OIF 650 inner head bolts.
The head may or may not fit well with the later '72 rocker box gaskets.You could always build it up with JB-Weld around the inner 3/8" bolts to get enough gasket surface for the rocker gasket.
TR6 used the same cams and timing as a T120.
Mr.Pete is offline
post #39 of 39 (permalink) Old 07-08-2013, 09:52 PM Thread Starter
This projest has been sold to someone with more money than I have.
Thanks for all the help and information.
I will be signing out for good now.
shaper is offline
TBS Project ussh Hinckley Classic Triples Picture Gallery 8 08-06-2013 03:49 AM
BC: Project TT SR RaceDweeb Air Cooled Twins Talk 19 09-04-2012 10:10 AM
Next Project! afakhori The Welcome Center 2 06-09-2012 12:31 PM
Another project softshoe The Welcome Center 1 02-05-2012 02:06 PM
New project 441!! TravThrux Classic, Vintage & Veteran 8 01-25-2007 12:09 AM
