1977 T140 - My 1st Triumph! - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGearMotorcycle.com
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 11-29-2012, 09:14 AM   #31 (permalink)
Main Motorcycle: T140 E
When I built mine,
I have AngloBike half race cams ( same as N. Hyde?) which use standard timing.
plus heavy duty valve springs, dural valve collars.
different exhaust as well.
DAVE M is online now   Reply With Quote
Old 11-29-2012, 10:55 AM   #32 (permalink)
Martin, that is a fantastic job of cleanup on the head. Sorry, I'm not a "non-spec-savvy" guy, so I can't help on the cams.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
GrandPaulZ is online now   Reply With Quote
Old 11-29-2012, 12:40 PM   #33 (permalink)
Main Motorcycle: 1978 T140 Bonneville
@DAVE M where dis you get that heavy duty valve springs and dural valve collars?
@GrandPaulZ it was done by local machinist 3 valve angle and full porting polished...
just bought a new wessel valve and guides, but i look around people tend to buy the black diamond valve, i also don't know where to get it...
i do some browsing for cams, 750 intake cams and 650 exhaust cams is a good combination of cams... and still using standard timing.
but found nothing on jomo15 or sifton 390 no review on street use....
MARTIN.K is offline   Reply With Quote
Old 11-29-2012, 08:42 PM   #34 (permalink)
"The T-75 is stock 750, pretty hot. The T65 is a BSA Spitfire grind. Your best bet is T75 T3 (Triumph triple). Sifton 390’s not so good for your purposes"
just got back from my cams maker, this is his reply please gives some comment for it.
either T-75 intake T-3 Exhaust or T-75 intake T-65 Exhaust
Old 11-30-2012, 07:02 AM   #35 (permalink)
My stuff came from the now closed AngloBike
but Norman Hyde do similar stuff.
You'd need an expert to tell you what to buy /use
https://normanhyde.co.uk/catalogsear...+valve+collars
Some advice on spokes for a 1977 T140 please BC1976 Classic, Vintage & Veteran 4 04-30-2012 04:32 AM
1977 T140 Drain Plug washer Dave W Classic, Vintage & Veteran 4 11-06-2010 11:19 AM
1977 t140 dennisbeaver Classic, Vintage & Veteran 0 03-05-2008 01:23 AM
1977 Bonneville T140 rocker shaft seals BonnevilleT140 Hinckley Classic Triples 1 01-20-2006 07:52 PM
Help 1977 t140 bonneville Classic, Vintage & Veteran 17 03-26-2005 08:37 PM
