John's 1972 T120RV project - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comSportbikeTrackGear
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 02-04-2012, 01:40 PM   #1 (permalink)
Main Motorcycle: 1956 T110
Other Motorcycle: 1972 T120V
The History.
For the past year, in preparation for a restoration, I have read the many threads in this “superior Classic and Vintage” forum of this site. I do thank all of you for your knowledge and willingness to assist the newer comrades in the undertaking of their projects. The documentation of your projects is excellent and I commend all of you on your restoration works of art. Now it is my turn to actually dive in with my project as a newbie, though I am a bit intimidated by your restoration masterpieces. (no, I’m not just brown nosing) I willingly accept all critiques, criticisms, and unsolicited recommendations regarding my project.
This is a new adventure for me of tackling a fine Classic British product. My previous bike experience was only Japanese. This project, a 1971 T120RV will actually be my number two Triumph. My first one, still collecting parts, is a 1956 T110 rolling basket case I purchased in February 2011, which will be on temporary hold while I work on the recently purchased T120.
This fine machine, matching numbers, was found a short jaunt from my local area in which I spent $400 to be the proud owner. The gentleman I purchased it from found it in a trash heap he was hired to haul away to the dump. He didn't have any desire to work on it since he was a Harley Davidson guy. At least he had the foresight to keep it and didn’t take it to the dump. In spite of the many years of exterior exposure in a trash heap, this bike looks relatively new compared to some of the before pictures of projects I have seen on this site. My goal is to rebuild it as close to original as I am able, with a few slight mods. I’m not trying to build a showpiece, though I hope it will be a good looking, nice riding, well functioning machine.
Before a wrench was turned, these are the before pictures; after the initial cleaning of the mud and large chunks of debris and the removal of a few black widows emerging from the bowels within.
jpj441 is offline   Reply With Quote
Old 02-04-2012, 02:09 PM   #2 (permalink)
A couple of nice mods from a previous owner. One, was the clever use of some garden hose and a finish nail for the fuel tank/mount stabilization.
Another was the use of two 1/2 inch galvanized pipe couplings for the “Metalastic Bushing” for the handlebar eyebolt. The rear fender was cut short, and the original tail light mount with the addition of an extra large Honda lens was mounted well forward. Finally, a generous usage of a rattle can satin black….rims, hubs, chrome fenders, handlebars, etc..
Old 02-05-2012, 07:52 AM   #3 (permalink)
Main Motorcycle: 71 Bonneville
david_in_ky's Avatar
Other Motorcycle: HD ultra Classic
Extra Motorcycle: Hd Low Rider
You are going to learn a lot about what not to do as well as what works. Take your time and it will come together......The pics are great...you will really have before and after that will remind you how far you have come...I had a lot of fun ( and some frustration) with my 71 T120...pics are here:
http://s571.photobucket.com/albums/ss160/david_in_ky/
[B]
david_in_ky is offline   Reply With Quote
Old 02-05-2012, 10:58 AM   #4 (permalink)
Ah! An excellent "before" picture!
Are you shooting for "Most Improved" in 2012, or 2013? hee hee
Thanx to everyone who has taken the time to post thier project threads here, they are a HUGE resource to the worldwide Triumph community.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 02-05-2012, 10:59 AM   #5 (permalink)
Actually, that's a pretty darned good donor project; the frame appears unchopped. That's a rarity for OIF choppers; they almost ALWAYS have the rear loop chopped off for whatever reason.
My stack of fork tweak bars is up to four now...
GrandPaulZ
Born Again Bikes
My Photo album
Old 02-05-2012, 11:36 PM   #6 (permalink)
David, thanks for the encouragement. I am thoroughly looking forward to this adventure. I have admired your project from afar. Well done!!
Paul, Most improved for 2013? I should have started last year!
Paul, you had mentioned to weld the frame near the swing arm spindle area whether cracked or not. The area I would be aiming at with the welder is within the box in the photo. Is this the correct area you were referring to?
A few questions for the experts.
On the front frame two down tubes abeam the “barrel to case” location, welded on are two small pieces of steel. I have viewed numerous pictures/manuals and have not seen any other bikes with this “unique” feature. I cannot determine what they are for other than a high "easy rider" foot peg bar in which may have been added by a previous owner. Does anyone by chance know what these are for? If they are of no significant purpose, I will just cut them off. Also, near the same location just below these two pieces of steel, the down tubes are a bit dented on both tubes. Any recommendations on the repair of the dents other than fill with a weld and grind them back into shape?
On the top tube portion of the frame, there was a poor weld at the front of the frame top tube. I could not determine if someone had tried to change the rake of the front end a little bit by cutting out a small section or if it was just a repair. The frame pictures I have looked at, the top tube has been straight up to the head tube. As you can see in the photo, this top tube has a small bend at the weld in which seemed a little odd, but I could not see any other bends/welds in any other parts of the frame necessary to counteract that upper bend. Any comments or recommendations other than clean up and re-weld? Thanks for your assistance.
Old 02-06-2012, 07:18 AM   #7 (permalink)
Main Motorcycle: 1974 T120V
Other Motorcycle: 1972 T120R
Extra Motorcycle: Kawasaki ZZR1100
That frame is trashed. Too dangerous, throw it away before it kills you.
Mark
mark61120 is offline   Reply With Quote
Old 02-06-2012, 09:52 AM   #8 (permalink)
Moderator
Main Motorcycle: Rickman T120
Other Motorcycle: T160,TR6
I think the frame is repairable.They're only welded together in the first place,and it's not exotic steel.
For the top tube to be bent,there must also be some bending of the front downtubes,relative to the steering head.Some measurements might be necessary,to work out where they did it.
The flat blocks can come off the downtubes.
I wouldn't weld up the crush marks.Just use filler and avoid distortion.I know other parts are already distorted;less is always better.
Mr.Pete is online now   Reply With Quote
Old 02-06-2012, 04:59 PM   #9 (permalink)
Jpj441,
Mr Pete is a very knowlegeable and clever guy, so if he thinks it is repairable, then he probably has the experience of repairing something worse and it has worked out ok.
That said, Mr Pete has access to people whom he can trust (or he does it himself) and what facilities (or access to experts) that you have, is an unknown. The quality of the repair may then not be up to the standard that Mr Pete would find acceptable on a bike capable of over 100 mph.
He is undoubtably correct in that the down tubes will have been altered in some way to get some kind of rake. There are correct ways of doing this that results in a safe job. Looking at the spine, I would think that the down-tube slugs have been bodged too.
There are repairs that could be made to the frame. I would sleeve the spine internally and pin it prior to welding the cut. Maybe even an external sleeve too for safety? The down-tube slugs would have to be cut out and new fully internal slugs machined and pinned/welded into place.
However, and I know everyone would ideally like a matching numbers bike, unless you have access to someone who REALLY knows what they are doing, get a new frame. It may even be cheaper than patching the existing one.
Mark
Old 02-06-2012, 08:00 PM   #10 (permalink)
Thank you Mark and Mr. Pete for your helpful advice, it is very much appreciated. Looks like another one of those unknowns that get discovered during a rebuild. After I remove the paint from the spine and down tubes and get a good look at what is hidden under the paint, I will figure out what will be the safest course of action with your recommendations.
John
1972 Triumph Trophy 650c Project thomasbowins The Welcome Center 1 01-28-2012 11:29 AM
1972 T120RV 5 speed question chopperat Classic, Vintage & Veteran 19 01-13-2012 08:32 PM
My 1972 T120 Project dwallace110 Classic, Vintage & Veteran 2 09-01-2010 09:38 AM
my new project 1972 t120r dwallace110 The Welcome Center 2 08-26-2010 09:47 PM
John's upcoming chain and sprocket thread Sprint Forum 14 02-26-2004 10:39 PM
