The spigot that's tight will be almost impossible to remove.You would need to destroy it to remove it without damaging the head.Grind through it in two opposite spots until you can see the threads in the head.Even then it might not be easy.
If the loose one still has some thread left in the head,you could make a spigot with an oversize thread.I think they are available,if you know what oversize you need.The standard thread is 1-1/2" x 16 tpi.
If the thread in the head is unusable or totally gone,the normal fix is to tap it out to a bigger size;which I reckon is stupid.These threads are more trouble than they're worth.
If you bored the hole out round again,a tight-fitting parallel spigot would work better.It would need to be a shrink fit,like a valve-guide.
