68 t100c teardown and rebuild - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 10-19-2010, 10:46 AM   #1 (permalink)
Main Motorcycle: Trophy 500
yagman's Avatar
Well, I picked this bike up in the spring and it is a nice runner, but it shows 40 years of rust. I had a few issues running it this year, mostly minor, but am going to tear it down over the winter and see what I have, mostly concentrating on getting the frame touched up and the cosmetics updated. Have not decided on the engine. Liek I said it ran nice, started easy, the only issue i have is some oil on the left side cylinder head after being driven, it would burn of and be fine while riding but after sitting in the garage on the side stand it would build the oil back up on the cylinder fins. I did a carb rebuild and new air cleaner late in the fall when it started to stall out on me, and it ran fine after that. Tank is currently out at the painters being restored to the original 'Trophy 500'. We will see how it goes.
yagman is offline   Reply With Quote
Old 11-30-2010, 10:09 PM   #2 (permalink)
yagman's Avatar
frame done
well the easy part is done, I have the motor out and the frame torn down for powder blasting or painting. No huge suprises, mostly rubber gaskets that need replacing, cleaning polishing, some bolts to replace, but generally everything was in pretty good shape. The oil tank had been repaired with some fiberglass, see the photos, so I am seeking a used replacement, as I am not sure I will be able to blastg and repair this one. Next will be the motor teardown.
Old 04-17-2011, 10:06 PM   #3 (permalink)
yagman's Avatar
been too long since I posted, have the bike torn down, lots of rust and age on the frame and bolts. tore down the forks, had a heck of a time getting the dust excluders off, and then getting the oil seals out, they must have been in there a long time. Brute force was the final answer after a few days of alternate soaking in WD40, PB penetrator, and the stanchions were pretty much shot, see the 3 pics, so I have replaced those and the oil tank. Am waiting to get the frame and various pieces back from the powder coater and get started on rebuilding the frame.
Old 04-17-2011, 10:08 PM   #4 (permalink)
yagman's Avatar
rust rust rust, and I don't know how the chain did not tear apart the wiring!
Old 04-18-2011, 06:41 AM   #5 (permalink)
Main Motorcycle: '77 Bonneville T140V
Garioch43's Avatar
Isn't amazing how good a bike looks from a few feet away!
It's only when you start taking apart that the true condition becomes evident.
You've got an interesting project on your hands and we look forward to watching your progress.
Good luck!
Sam Murray
Aberdeen, Scotland
Garioch43 is offline   Reply With Quote
Old 04-18-2011, 07:29 AM   #6 (permalink)
Main Motorcycle: `71 TR6R
Other Motorcycle: `73 TR7RV
Extra Motorcycle: 2005 Ducati 999
Good luck!
Imagine how good a bike looks to someone hot to buy a bike before summer and it`s not hard to see how so many guys end up with repair and rebuild projects rather than rideable bikes.
I`ve never been dissapointed buying a rolling basketcase yet because I know exactly what to expect.
MoBe is offline   Reply With Quote
Old 04-18-2011, 08:55 AM   #7 (permalink)
yagman's Avatar
more shots from various stages of the teardown, wuill need a new harness, found lots of splices in the wring, but we finally made it to the end
Old 04-21-2011, 01:21 PM   #8 (permalink)
Main Motorcycle: 97 Harley.. Dyna Lowrider
dossbag's Avatar
Other Motorcycle: 71 Triumph Daytona
Extra Motorcycle: 80 GS550
Good luck.. I'm in the same position.
I got two Daytonas.. a 71 and a 72.. hoping to get a runner from both, but didn't realize how much work I set myself up for.
Actually, one engine is stamped T100C and the other is T100R.
I'm learing a lot.. and having a (PB) blast..
dossbag is offline   Reply With Quote
Old 04-23-2011, 09:01 AM   #9 (permalink)
Main Motorcycle: 1970 Bonneville
Other Motorcycle: 1968 T100C
Extra Motorcycle: 1967 Daytona
Wow Yagman, I wish my 68 T100C looked that good when I got it!
TampaTriumph is offline   Reply With Quote
Old 05-17-2011, 07:55 PM   #10 (permalink)
yagman's Avatar
is there a specific orientation for the swing arm spindle grease holes when replacing the swing arm shaft? do they align vertically, horizontally or does it not matter? I don't remember how they were when they came out.
Toxic's T100C engine rebuild part II - lots of pics toxic Classic, Vintage & Veteran 11 09-24-2010 03:15 PM
1971 T100C Trophy top end rebuild toxic Classic, Vintage & Veteran 16 04-25-2010 01:54 AM
teardown tips ecose Classic, Vintage & Veteran 1 04-13-2009 06:32 AM
New Rebuild-Won't start (T100C) argie Classic, Vintage & Veteran 4 10-16-2008 07:51 AM
Sprint top end teardown firemanjim Sprint Forum 1 02-05-2006 06:38 PM
