Loctitekid's 1959 6T - Page 19 - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 11-18-2012, 06:48 PM   #181 (permalink)
Main Motorcycle: '59 thunderbird
Other Motorcycle: '95 Thunderbird
Hi Paul, thanks for your interest.
Haven't tried to fit all this yet.
Waiting for a new lower fender stay to replace my home made one, then I'll take things apart.
From bitter experience, I keep the bike in rideable condition until I have everything in my hands ready to go for reassembly.
loctitekid is offline   Reply With Quote
Old 11-19-2012, 10:51 AM   #182 (permalink)
I would chop it off before powdercoating.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 11-25-2012, 02:08 AM   #183 (permalink)
First attempt
I decided to remove both bottom members, because there was some leakage of fork oil from the left one.
Dismantling was easy. I took the wheel out, mudguard off, then unscrewed the allen-headed bolt in the bottom member that is concealed by the axle. That allows the bottom member to drop right down, end exposes the top of the seal holder. Unscrew the seal holder, and the bottom member slides off leaving the bushes and seals in place. I used a bolt in the mudguard mount boss to turn the bottom member while I held the seal holder with a C spanner.
Assembled the wheel with the Trumph backing plate in place of the BSA backing plate, and mounted it up. Looks good, no interference with the nave plate, nothing to take off or modify.
Problem is that the brake drum rubs on the inside of the backing plate. I'll have to take the wheel out again to dismantle it and fit a shim for clearance. It's only just touching, so it won't need much.
And I messed up modifying the brake cable to fit. The outer needs to be longer, and the inner needs to be the same length as before. After my efforts, now the inner is so much too short that I can't fit the cable.
My local bike shop is closed today, so it will have to wait until Monday night after work. Fortunately generic brake cables are cheap and plentiful.
Even though it's been three steps forward and two steps back, it's been a good day. It looks like it is all going to work at last.
I have the correct lower mudguard stay, but it doesn't fit nicely with my late model mudguard, so I am keeping my handmade one in use until I can score a correct guard.
I also scored a right hand choke lever (it's in the post), but I suspect it's for 7/8" bar, so it will have to make the acquaintance of Mr. Dremel, like my left hand lever did.
Old 11-26-2012, 11:25 AM   #184 (permalink)
Main Motorcycle: The one between my legs
Snakeoil's Avatar
Other Motorcycle: '76 Triumph T140V
Extra Motorcycle: Yes
Glad you finally reached the end of what was a very long and winding road.
Now please paint that damn homemade fender brace black, willya. Geesh!
regards,
Rob
Snakeoil is offline   Reply With Quote
1959 Bonneville on eBAY bushybester Classic, Vintage & Veteran 13 04-11-2010 12:19 AM
Red 1959 Bonneville corteso Classic, Vintage & Veteran 28 09-04-2009 02:24 PM
Nice 1959 TR-6 MarkRoberts Classic, Vintage & Veteran 5 05-11-2008 12:05 PM
1959 650 zuddler Classic, Vintage & Veteran 2 05-09-2008 04:10 PM
Von Dutch 1959 Thunderbird triumph_955_st Hinckley Classic Triples 0 10-08-2005 03:10 PM
