Having problem removing gearbox - Any advise? - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 01-31-2010, 08:33 PM   #1 (permalink)
Hello,
I have a 1969 T100S Triumph. Am in the process of restoring the bike and now stuck.
The manual states the bike should be in 2-3 gear to remove the gearbox. When I got the bike I was unable to switch gears.
I know the bike is not in the proper gear to remove the gearbox but looking for advise. Is there any other way to remove the gearbox or do I have to find a way to get the bike into the proper gear?
Many thanks,
Adam
Having problem removing gearbox - Any advise?-gearbox_1.jpg   Having problem removing gearbox - Any advise?-gearbox_2.jpg
newtriumphowner is offline   Reply With Quote
Old 02-01-2010, 09:29 AM   #2 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi newtriumphowner
I have just been having a look at parts catalogue#7
as you are not sure what gear it is in and it looks like the camplate can hold the casing on
because of the way it attaches to the selector forks.
You should try and remove the pin (camplate spindle #26)
and release the camplate from the outer case. then remove the outer case and leave the camplate in the box.
This way you should be able to seen what's wrong in the box.
I think this should work for you though I am not familiar with your bike.
Plewsy is online now   Reply With Quote
Old 02-01-2010, 09:38 AM   #3 (permalink)
Plewsy,
Thanks for your feedback.
I will try that tonight.
Old 02-01-2010, 11:10 AM   #4 (permalink)
Favourite Bike: '67 Triumph Bonneville
Remove the clutch and pull the entire cluster out complete.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 02-01-2010, 10:37 PM   #5 (permalink)
Was unable to remove the camplate spindle. Soaking tonight with some PB Blaster.
GrandPaulZ - can you explain a little more, I don't fully understand.
Old 02-01-2010, 11:21 PM   #6 (permalink)
Favourite Bike: 70 Triumph T120R Bonnie
shrugger's Avatar
Other Motorcycle: 72 Norton Commando
Extra Motorcycle: Royal Enfield Bullet 500
Borrowed from ed_h's most excellent rebuild.
Clutch
entire cluster
"Thanks to denial, I'm immortal" -Phillip J. Fry
shrugger is offline   Reply With Quote
Old 02-02-2010, 07:59 AM   #7 (permalink)
Thanks shrugger for the great pictures !
I will try to remove the clutch tonight and hopefully the gearbox comes out.
Thanks again.
Old 02-02-2010, 08:25 AM   #8 (permalink)
shrugger's Avatar
I momentarily forgot that the final drive sprocket will need removed
as well. Whole thing should slide right out then.
Old 02-02-2010, 09:32 AM   #9 (permalink)
newtriumphowner my idea will not work, from the pic's shrugger posted it looks as if there is a "split cotter" through he spindle
shrugger can the final drive sprocket not be left on, as the mainshaft should pull through the mainshaft high gear leaving it in place?
Old 02-02-2010, 10:06 AM   #10 (permalink)
shrugger's Avatar
hmm, I'm not completely familiar with the 500 tranny. I think you
might be right about that though. However, not knowing why this
tranny is stuck. It's a good idea to pull everything out to inspect.
A Simple Spark Plug Problem - Advise Please crowtherstephen Tiger Workshop (archive) 3 10-05-2009 04:34 PM
Removing Fuel Tank - helpful advise please ? Straniero Daytona675 Forum 6 03-08-2008 10:11 AM
Got a problem...please advise. 2112 Twins Technical Talk 14 05-11-2007 08:21 AM
TR7V Gearbox problem veloman Classic, Vintage & Veteran 4 09-25-2005 04:23 PM
Gearbox problem? Maintenance & Workshop Talk 2 06-07-2004 10:00 AM
