best timing - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 01-26-2010, 04:43 PM   #1 (permalink)
best timing
what is the best timing for a 1972 bonnie? To make it easy to start, I'll have to use my left leg with it on center stand, right knee is bad. I have a boyer elect, is set on 38deg. befor tdc.
D'Ray
"take care"
D'Ray is offline   Reply With Quote
Old 01-26-2010, 05:24 PM   #2 (permalink)
Favourite Bike: T120R Bonneville (mine)
Other Motorcycle: I wish
Hi D'Ray
have you strobed the timing?
Static = 38deg BTDC, white dot through the hole in Boyer.
It should start, warm it up.
Strobing
Run the motor 3500-4000rpm and the 38deg marker lines up with pointer on the case.
You should confirm the position of mark on rotor using the timing hole plug.
If the mark on rotor and the pointer on the case are lined up at TDC,
you need to make another mark on rotor at the 38deg BTDC position and strobe using the new mark.
the screw hole directly behind the pointer can be use to get 38deg.
Plewsy is offline   Reply With Quote
Help with timing on a 56' TR6 michaels90na Classic, Vintage & Veteran 5 06-15-2008 11:48 AM
cam timing Speedblue2 Twins Technical Talk 19 02-01-2008 05:04 PM
Cam Timing rickster Daytona Deliberations 5 08-11-2007 05:24 PM
timing musicman59 Classic, Vintage & Veteran 0 09-11-2005 08:08 PM
need cam timing help .please Maintenance & Workshop Talk 10 02-29-2004 01:58 PM
