Pile of Tiger Cub Bits - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 09-16-2009, 05:45 AM   #1 (permalink)
Favourite Bike: T140 E
http://s794.photobucket.com/albums/y...albumview=grid
I bought this pile of bits which is basically a complete bike but in "kit" form. The PO or one before (a mate of his) took the whole thing apart with a veiw to a resto/rebuild but ran out of steam.
he said it's 1959 but its'a 60 model designation Pretty sure that I over paid at £450 but enthusiasm took the better of me.
I'm in no hurry as I just fancied a pile of bits to work on at some point so I'm going through the paint trays that it came in and photographing and reboxing the pile.
It would have been far easier to have done the strip myself though.
I have a genuine parts manual that's imaculate so I intend to photocopy it and then tick off the individual parts before bagging using self seal or sandwich bags.
It's missing the front mudguard, the back part of the rear, the bikini panels and a small part of the rear chain guard. I could get all those bits for about £100-150 if I wanted. Cheaper from autojumbles but then I'd need to travel....
The forks are in bits but I have the complete nacelle.
The engine is completly stripped and the bearings renewed but then he gave up. He thought that the best barrel was the square one but I'll look into it. It should have the round one.
the wheels are terrible and are 18 x 3.00 Bantam cub?
My idea was either to do it up as standard or, as I have a plunger cub, (56 frame and 1960 engine) pinch the nacelle top (the plunger one was modified by a PO and has large H/bar holes cut out) and maybe fit H weight foks and make a period style off road type bike with high exhaust and knobbly tyres
I always fancied a trail type bike and two semi identical models is a waste. I thik the plunger ones and the later mountain cub were the best lookers, the 60 version was a bit lumpy looking
My plunger front mudguard is the same part so as it's a bit dented at the front after a prang, I could source a new plunger one and donate the old one to the build.
Whatever I do, I won't disguard any original part, I'll keep it incase a future owner wants to revert.
The anoying thing is that I had a garage clear out and gave three pairs of forks to the local breaker. Knowing his ramshackle shed, they're still there and I'll buy them back if they fit.
Anybody know how to identify the H weight forks? it's been years since I looked at a set. I think that the same forks wwere fitted to all triumphs of the 50's and 60's? I have a spare lightweight yoke so I can check dimensions. Casting numbers on the yoke?
My plan is to sort out the pile, rebox, store and finish my other projects.
I might temporarily bolt the frame together to use up the tin of bolts and see what's there but I'd store it as is untill the build proper.
Then rebuild the engine maybe to a sportier type (but I doubt it) and once that's done, make a bike to fit. I guess that I could test the engine in the other bike.
Over here, the number stays with the bike and i have that. Last taxed in 76.
Don't hold your breath
DAVE M is offline   Reply With Quote
Old 09-16-2009, 06:38 AM   #2 (permalink)
Favourite Bike: Triumph Bonneville
Other Motorcycle: Triumph Speedtriple
Hi Dave,
Looks like a nice project, but a lot of work!
Webby
Webby is offline   Reply With Quote
Old 09-16-2009, 07:38 AM   #3 (permalink)
Tell me about it!!
I have an original, pristine parts catalogue, lots of self seal bags and a radio.
I've photocopied the catalogue and will "sacrifice" the copy by ticking off the smaller parts and labelling the bags, storing in plastic storage boxes until I'm ready.
I'm in no rush and intend to start the build this time next year unless I catch up on other projects earlier than expected.
Old 09-16-2009, 10:35 AM   #4 (permalink)
slight edit
can anybody tell me if H 1327 or H1256 is the part number for any other bike's front forks? (97-1256)
I think it's the C range that was fitted to the 3TA
all the internal part numbers seem to be the same and the spring colour code is the same
Old 09-16-2009, 10:46 AM   #5 (permalink)
Favourite Bike: '67 Triumph Bonneville
Dave, best to post some pix as soon as you can; it helps in "translation".
Sounds like you have your hands (and garage) full!
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 09-16-2009, 12:47 PM   #6 (permalink)
Hi Dave,
I've been surfing the net and came across this and thought it might be interest to you.
http://www.vintagebike.co.uk/Classif...ub_spares.html
Webby
Old 09-17-2009, 07:47 AM   #7 (permalink)
I posted this link
I've investigated the options and I can get all the bits to make a nearly new set of HW forks for about £450 (lots of new bits but "good" used sliders and yokes) or buy "refurbished/overhauled" from a tiger cub specialist for £350 - if he has any.
I want to keep the costs down but will probably disregard the original bits that I have and go HW forks, older style tank (£30) and just paint the rims for a start.
At the moment, I've photopied my parts manual and I'm sifting through the pile of bits.
The Po took it all apart and stored it in paint trays! No labels, valves in with the gears and pistons with the shot electrics
I'm putting everything in self seal bags and plastic boxes, making a list and will build the engine over the winter. Once I feel confident, I will consider the cycle parts.
The bike cost £450 as is (adding a tenner as I got caught by the London congestion charge - a toll)
So it will be worth maybe £1k finished. Not that I intend to sell but I need to be sensible. I can add flashy bits later but like the look of period bikes.
Old 09-17-2009, 10:29 AM   #8 (permalink)
AHA! I see that would take some doing to post all of those, JUST FOR A START!
Maybe if you pile everything up out in your driveway and stand on a ladder for a "before" shot of the pile of parts...
hee hee
You definitely have your hands full. That will be an excellent project when it's done.
GrandPaulZ
Born Again Bikes
My Photo album
Old 09-17-2009, 11:17 AM   #9 (permalink)
actually, it's all in the small TV studio where I work. I have a few days grace to sort it before it needs to get home.I'm spending this weekend throwing stuff out of the shed.
If I can, I'll do as you suggested and take a ladder shot for fun!
Webby....
thanks for that. I need to decide what's there first and try not to go mad with the budget. Greystones are the Tiger Cub specialists and have most stuff but sort of control the market as they buy a lot of what's around, and then people use them as a guide for their own sales.
Old 09-17-2009, 01:25 PM   #10 (permalink)
Looks like fun!
My bonnie arrived in a similar condition but at least the PO only dismantled the top half of the engine!
Good Luck with it
Also isn't Hughie Hancox and bit of a cub specialist?
Webby
Part numbers for Tiger bits tigertales Tiger Workshop (archive) 0 05-28-2009 12:19 AM
Daytona bits into Tiger?? Nigeh Tiger Mods & Bolt-Ons (archive) 7 05-22-2009 03:52 PM
Need some bits for my Tiger chris haigh Tiger Chat 2 02-25-2008 10:36 AM
A.I Bits again DannyChrist Twins Talk 8 07-30-2007 07:02 PM
The 05 accolades continue to pile up OMEGA Speed Triple Forum 4 06-08-2005 03:15 PM
