newbie question on engine model year compatibility - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 09-08-2009, 10:05 PM   #1 (permalink)
Can anyone tell me if a 1979-1982 vintage t140 head will work on a 73 T140 lower end? They both are 10 bolt units but need to be sure.
Thanks
70Trophy is offline   Reply With Quote
Old 09-09-2009, 12:12 AM   #2 (permalink)
Favourite Bike: '03 T-100 & '08Tiger1050
This forum is for the 2001 and later Bonnevilles, and though someone on this forum may be able to answer your question, you would probably get more and faster results on another fourm.
Look on the left side of your screen at the listing of the forums. Click on "Classics and Vintage" and scroll down a ways in that forum till you find the Meridian models and click on that forum. List your question in that forum and you will probably get a quick reply.
Larry
Old 09-09-2009, 12:23 AM   #3 (permalink)
RE:newbie question on engine model year compatibility
Thanks Redbird
Old 09-09-2009, 12:42 AM   #4 (permalink)
Favourite Bike: Bonnie black
Haggis's Avatar
Other Motorcycle: Sprint RS
It's moved.
OK you classic guys, it's your turn - we were crap!
Haggis is offline   Reply With Quote
Old 09-09-2009, 01:03 AM   #5 (permalink)
Favourite Bike: '67 Triumph Bonneville
All 10 bolt should work together. Perhaps a specific set of pushrod tubes may need to be used.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 09-09-2009, 09:46 AM   #6 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
They will bolt up to the cylinders and run fine but the carburetor manifolds are different (and I think the air boxes are too) on the 79-82. The Manifolds on the 79-82 heads point straight back instead of being splayed outward and the carbs are held on by rubber hoses instead of being bolted solid to the manifolds. There is no provision to attach the earlier carbs to the 79-82 manifolds. If you're building something this might not be a problem but if you are installing it on a stock bike and planning to reuse your existing equipment (carbs/airboxes?), it will.
jimmy bush is offline   Reply With Quote
Least engine vibes which year and model singring Classic, Vintage & Veteran 9 07-11-2009 06:51 PM
What model/year is this Voigtlanderr2 Classic, Vintage & Veteran 16 12-07-2008 06:38 PM
Why not buy a new model every year? dazco Twins Talk 15 07-28-2006 08:52 PM
What Year model is it? sgtdcutchin Maintenance & Workshop Talk 1 02-05-2006 06:38 PM
What year model do I have? Triumph SuperSports 3 05-26-2004 12:05 PM
