Part 4
It started with a vengence...revved to about 5000rpm.
The saddle foam disintegrated, Orangey bits & powder everywhere.
The sliders were hanging.
The saddle was knackered, so I made another.
I persevered, but the damage was already done.
Smoke.
This was not unexpected...it had always been that way.
It was also wet-sumping. Pump not perfoming efficiently.
New oil pump and oil-pressure relief valve.
But as stated earlier, the engine had new pistons and rings, +0.040.
Not rebored, I think.
However it was tweaked, it smoked...snide remarks from neighbours.
And the oil puddle.
Primary case off, the long grommet was split, perished and had fallen off.
Off with head and barrels.
The valves appeared to seat gas-tight but loose in the guides.
The bores were tapered and large ring gaps.
The head was farmed out.
On receipt of the head, the notes said, "use a 3.5 slider, and .105 needle jet, iridium plugs and the timing may need retarding."
The head bolts were loose in the barrels, this and everything else considered, I bought a new standard barrels complete with pistons and rings.
I thought I might as well do the small-ends.
Engine reassembled, check oil return...OK.
Strange clicking while kicking-over with plugs out.
Long forum debate...turned out to be exhaust pinion loose, I could undo it with my fingers.
The only reason I found that was because some of the members here suggested the timing marks were wrong.
I should remove the nuts and check the keys/keyways.
The inlet pinion was moved to align with the long dash on the intermediate pinion.
All buttoned up and she fired-up. Grrrreat and no smoke.
On another thread, "T120V bites back" is a description of how my brother was almost launched, and suffered leg injuries.
I have retarded the ignition timing.
Next installment...gearbox!
I`m only doing this now because I`m waiting for spare parts.
