Top Yoke "Metalastik" Bushing help - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 06-06-2009, 10:50 PM   #1 (permalink)
crazywelder72's Avatar
Does anyone have any experience, tips, or secrets on how to knock out the bushings on the Top yoke?
Do i have to take the top yoke off the bike and press them out? I tried to drift them out but I wasn't having any luck so I just decided to rely on all of you for some guidance.
I got the brand new ones standing by just dying to go in.... just need to get the old bastards out first.
crazywelder72 is offline   Reply With Quote
Old 06-07-2009, 06:01 AM   #2 (permalink)
Favourite Bike: '74 850 Commando
daveforty's Avatar
Other Motorcycle: '79 T140E
Extra Motorcycle: '06 Scrambler
Easier if you take the top yoke off first. The bushings are a tight fit to begin with, and do get stuck with a bit of corrosion etc. In the past I have used a junior hacksaw blade down the centre to make a cut through the length of the bushes and then pry them out with an old screwdriver.
daveforty is offline   Reply With Quote
Old 06-07-2009, 09:56 AM   #3 (permalink)
Favourite Bike: Triumph TR7V
Other Motorcycle: BSA B40 SS90
Extra Motorcycle: Buell M2
Managed to drift mine out OK. The yoke was off the bike and solidly supported below the bushing. I also soaked in penetrating oil for a couple of days and applied some heat.
I used the proper service tool drift.
Badger
394c is offline   Reply With Quote
Old 06-07-2009, 10:29 PM   #4 (permalink)
thanks a lot... i removed the top yoke and pressed out the inner core, then used a normal hacksaw blade by hand to cut through the outer steel part. once that was done, it only took a couple light taps with flat head screwdriver and they popped right out.
thanks again,,,
Old 06-08-2009, 11:02 PM   #5 (permalink)
Favourite Bike: '67 Triumph Bonneville
Hammer them out with just the right sized drift or socket to hit the entire bush outer ring.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
No Taillight in "ON", Have tail in "PARK" zebulonsmith Tiger Workshop (archive) 2 07-19-2008 05:15 PM
Combining my "seat heat" and "tune" threads here TheNomad Sprint Forum 10 06-02-2008 01:09 PM
a "clack" and a "clunk" sjalex Twins Technical Talk 9 08-02-2007 05:10 PM
