73 TR7RV - top end or all rebuild - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 03-21-2009, 07:40 PM   #1 (permalink)
Favourite Bike: 2004 Bonneville Black
Imperial88's Avatar
Other Motorcycle: 1973 Tiger 750
Alright, i'm looking for opinions.
1973 tiger tr7rv...750cc.
Motor was taken apart due to hollow tin tin top end noises ...mainly on left side. I have no vertical wrist pin wear and no lower end bearing wear...both stated from physical feel not visual or measured observations. Cylinders look pretty good... i'm used to 2 stroke honda 125 motorcycles... Pictures say a thousand words... should i..
a. hone cylinders, put new pistons and rings
b. bring to well repuitable shop for an estimated $1500 complete rebuild bottom up.
I do love the bike and don't plan on selling it... the $1500 is steep and i would rather rebuild the top end only... but i also want to make the right decision and not have to take this thing apart in a short time.
Thank You
Zach
Imperial88 is offline   Reply With Quote
Old 03-21-2009, 07:46 PM   #2 (permalink)
Favourite Bike: Thruxton
I'd just do the pistons. If there is no play in the rods, etc. why fix what's not broken? If you are sure of the miles and the past engine work, I'd keep the coin.
davidc is offline   Reply With Quote
Old 03-21-2009, 08:40 PM   #3 (permalink)
Favourite Bike: 1958 Norton Nomad
Greaser's Avatar
Other Motorcycle: 2000 Triumph TBS
It really isn't much more work to pull the cases apart and refresh the bearings.
Ask yourself: Where did all the metal from the pistons scraping the cylinder walls go?
" If you haven't been paying attention to what's going on in the world around you perhaps you should start. It certainly beats relying on erroneous rhetoric to form one's opinions." Steven Lloyd
Greaser is offline   Reply With Quote
Old 03-21-2009, 11:22 PM   #4 (permalink)
Favourite Bike: 66 TT
Other Motorcycle: T140V
Extra Motorcycle: a bunch
I would mike the bores see if they need a rebore if not hone them and fit new pistons and rings and go for it. The bore may be worn and the pistons rocking in the bore, $1500 for a top end job is highway robbery. Gearhead
gearhead is offline   Reply With Quote
Old 03-21-2009, 11:42 PM   #5 (permalink)
Favourite Bike: '67 Triumph Bonneville
I'd do the whole enchilada.
Get ready to spend $2500 for a like new farmed out job.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 03-22-2009, 08:41 AM   #6 (permalink)
Imperial88's Avatar
$1500 was the quote to rebuild the entire engine. So is this what we are leaning too.... i have not mic'd the cylinders yet..i plan to after work today..hmmmm
Old 03-22-2009, 10:54 AM   #7 (permalink)
Favourite Bike: 1968 Triumph Bonneville
Other Motorcycle: 2008 Harley Fat Bob
$1,500 for top and bottom rebuild? Definately on the low end from the limited information Ive seen on rebuild costs. May I ask what shop quoted you that and what that includes. E.g. is that for a basic rebuild and may have to add on depending on what they find once they look?
Keep us posted -- ill be looking to do something similar soon.
Cheers.
Kev_England is offline   Reply With Quote
Old 03-22-2009, 12:56 PM   #8 (permalink)
Favourite Bike: Triumph TR7V
Other Motorcycle: BSA B40 SS90
Extra Motorcycle: Buell M2
Cheers.
Back in the UK look to spend £4000+ for a full rebuild by top name company. Did have 4 pages of A4 listing the parts replaced/upgraded though.
Badger.
394c is offline   Reply With Quote
Old 03-22-2009, 08:51 PM   #9 (permalink)
Imperial88's Avatar
Ok... i need assistance... obviously i do not want to drop the big $$ on the motor if i don't need to.
I have taken each piston off and made an attempt to get mic'd numbers off of them...i have put them skirt first into the bottom of the cylinder and find a good amount of play...
Now i have attached some more pics... i'm trying to figure out if these are suposed to be standard bore pistons or if they are oversize....the only markings i can find on the pistons are "T1176" and a number #1 under one piston and a #5 under the other..
I have an old Clymer manual... and do not find it user friendly
thanks
Old 03-22-2009, 09:08 PM   #10 (permalink)
Favourite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast
that's just the casting # , normally the pistons are marked on the crown , the top , under all that carbon they should be stamped .
Woody1911a1 is offline   Reply With Quote
Overheating in very hot weather - 73 TR7RV jonkull Classic, Vintage & Veteran 20 12-27-2008 07:06 AM
TR7RV Suspension... jonkull Classic, Vintage & Veteran 6 09-19-2008 08:08 PM
73 TR7RV question tangomike Classic, Vintage & Veteran 7 09-07-2008 05:35 PM
'73 TR7RV - Did I hurt my engine? jonkull Classic, Vintage & Veteran 9 06-12-2008 06:40 PM
Max RPMs for a 73 TR7RV jonkull Classic, Vintage & Veteran 2 03-03-2008 10:05 PM
