First adventure in opening up my '79 T140E Bonnie - Triumph Forum: Triumph Rat Motorcycle Forums
Member's Restoration & Rebuild Projects Details of member's own projects.
Old 01-16-2009, 03:22 AM   #1 (permalink)
Favourite Bike: 1979 Triumph Bonneville
bergvw8's Avatar
Yep.... I've learned a valuable lesson.... Don't ride my 79' T140E from Phoenix to Tuscon at high noon on one of the hottest days this summer, and pretty much wide open... yep....
Gnarly huh? But I'm looking at it from the perspective that I have time on my hands and am having a great time working on it....
Here's where I'm at....please fell free to advise me on anything i'm doing wrong....
I've got the pistons removed. There is some aluminum on the top of the connecting rod (see picture) that looks a lot like the metal build up that occurs on an abrasive saw. I've checked and I can "chip" it off with my fingernail. I'm going to try and remove it all by hand, but am thinking I might be able to clean it off with a very soft dremel attachment.
I am really hoping to flush metal out of the crankcase instead of opening everything up.....is that even do-able or must I take the dive? I've drained the oil, and removed the oil filter (just planning to put a new one in when it goes back together)....Plan to remove the filter on the bottom of the crankcase and replace it...am having troubles getting it off....can't even get it off with an impact. Will try to remove tomorrow with a breaker bar and hope I don't tip the bike over....
As for the head, I've begun to clean it up with the previously mentioned dremel attachment, being very careful to stay away from any sealing points. really just cleaning out the carbon I'm finding in the cylinder dome. I've figured out how to remove the valves, and am in the process of cleaning the carbon off of them as well with the dremel. I bought a lapping stick and some lapping compound and will lap the valves before I reinstall. Any necessary reason to replace the valves or guides if they have been seemingly mechanically sound?
Now for the cylinders.... In reviewing all the service records for the bike, it has already been bored out .020 over. The cylinder walls have no gouges or grooves or scratches perceptable to my touch. I'm a little wary of boring it out any more if the walls are happy. Should I just bring it to a machine shop and have them hone the cylinders and put a micrometer to it and see if it's still +.020?
My haynes manual should show up on Monday, but I feel I've done everything properly so far.....
Thinking ahead, one point that is unclear to me is how I can torque the nuts for the cylinder base. I had to grind down a 1/2" box wrench just to get it on the 12 point nuts. I'm hoping to read in the Haynes manual that you only have to torque the head to the jugs. Do you recommend the brass head gasket? For all the other gaskets, is there a preferable gasket sealant? Any spray ons?
Would also appreciate techniques for polishing the aluminum on the crankcase. How about polishing the head?
Hope I haven't inundated you with too many questions, but I truly appreciate all your help.
Rick
PS Here's what she looks like (except I have a corbin seat on it now)
bergvw8 is offline   Reply With Quote
Old 01-16-2009, 09:18 AM   #2 (permalink)
Favourite Bike: '78 Triumph T140E
Other Motorcycle: '07 Ducati ST3S
Extra Motorcycle: '68 BSA B44B
Beautiful bike, ugly piston. After a detonation like that I would need to inspect everything from the crank up, just for my own peace of mind. If that engine hasn't been split in the last 30 years it's about time.
As it is, Andy
'78 Triumph Bonneville T140E
motersikelist is offline   Reply With Quote
Old 01-16-2009, 11:49 AM   #3 (permalink)
Favourite Bike: '67 Triumph Bonneville
Split the cases and clean the sludge trap. Mike the crank & rods, too.
I use "hand pounds" instead of foot pounds on many of the fasteners. You get a "feel" for tightness.
Besides, the torque figures are given for "dry", yet you are supposed to use Loctite on many engine fasteners!
You'd better address your holed piston(s) by carefully strobe timing your engine and getting your carb jetting correct. hot weather doesn't hurt bikes, improper tuning hurts bikes.
GrandPaulZ
Author of "Old Bikes"
Born Again Bikes
My Photo album
Old 01-16-2009, 06:51 PM   #4 (permalink)
Favourite Bike: '68' T120 Bonneville
Other Motorcycle: 2006 T100 Bonneville
Extra Motorcycle: '79' T140 street tracker
Nice looking bike. Sorry about the piston. A word of advice I got from an "old" Triumph guy (well he's a few years older then me) was if I ever holed a piston, to change the rod or it will come apart. I don't know how good the advice is but it makes sense to me. If the piston melted and the metal stuck to the top of the rod, the wrist pin area on the rod must have gotten pretty hot too. Aluminum isn't too tolerant of excessive heat. It tends to soften up (Annealed?). At any rate, the whole engine needs gone through to clean out all the aluminum flakes from the oil passages, pump, bearings and as GrandPaulZ said, the sludge trap. There is a tool that you can get for the cylinder studs. They're not but a few inches long and look like a 1/2" box end on one end with a 3/8" square hole for a torgue wrench or ratchet to plug into at the other end. I think they're called a multiplier. Pretty handy but you have to do some calculations to get the torque right if you use one. Good luck.
jimmy bush is offline   Reply With Quote
Old 01-16-2009, 10:07 PM   #5 (permalink)
bergvw8's Avatar
Thanks for the input so far!
Would love more input from others....and answers to some of the other questions in my original post.
Anyone use EMGO pistons? I found a very reasonably priced vendor in Scottland but the site is lacking a catalog. If you tell Grin what you need on the webform, he'll shoot you an invoice with speed and the price so far is very reasonable.
http://www.grintriumph.com
One last thing.... I ordered a complete gasket set off of eBay, NE Brand, and the head gasket appears to be steel on the cylinder side and composite on the outside. Should I just buy a copper one?
Cheers and again, I thank you all sooo much for your help!
Rick
Old 01-17-2009, 01:33 AM   #6 (permalink)
Favourite Bike: '72 Bonneville
RetroRod's Avatar
Other Motorcycle: Suzuki GSX1400
I would split the cases too, and very carefully check the con rods and crank. You can pretty much be assured that a flush of the bottom end will not clean it to the standard you require. I agree with GPZ about tuning. For my money a lean mixture has contributed to the high temp that burned the hole.
Lean mixtures can give you some get up and go, but they also increase the temp.
I hope things go well for the rebuild.
RetroRod is offline   Reply With Quote
Old 01-17-2009, 11:16 AM   #7 (permalink)
Favourite Bike: Any Triumph
Mastiff-man's Avatar
Bummer!!!! Before going any further, I would recommend you buying one of the engine rebuild video's for sale on Ebay...Your also going to have to buy some special tools.
Your complete oil system needs to be cleaned, including the frame..I'd go back with some type of oil filter just to be on the safe side......Good luck with it..
Mastiff-man is offline   Reply With Quote
Old 01-17-2009, 07:15 PM   #8 (permalink)
RetroRod's Avatar
Just picking up on the head gasket enquiry. Whilst I have no experience with warpage on a Triumph alloy cylinder head, your motor has been very hot and it will pay you to ensure the cylinder head is flat. A steel rule can be used to check this. The steel/composite gasket would be quite OK when used on good flat surfaces, ie, steel down, composite up. If there is any doubt about the surfaces, the copper gasket will be more forgiving and accommodate any slight imperfections on the surfaces of either the barrel and cylinder head.
Trust this is useful for you.
Old 01-18-2009, 03:14 PM   #9 (permalink)
bergvw8's Avatar
What special tools will be needed and where might I procure them?
Cheers
Old 01-18-2009, 06:18 PM   #10 (permalink)
Most of the part houses carry the pullers and different tools needed....I really would watch the video, than you can tell if your getting in over your head, and what all you need.. Your going to need a tap & die set so you can clean all the tread holes...
No one has mentioned it yet, but i would s-can the oil pump....The manuals give you the spec's on the length the head & rods bolts should be...your going to need to mike them to be sure they haven't stretched.....I would size both rods and have them shot -pinged...Sure wouldn't hurt to balance everything while your at it....
You might have it dyno tune it after you get done, so you know for sure everything is right....Cheers
It's Opening Day for BASEBALL KingBear Biker Hang-Out 24 04-05-2009 03:53 PM
Hard bags 2.0, or "Kevin's quest to build an Adventure Bonnie" Cat_Daddy Twins Technical Talk 22 07-11-2008 11:49 AM
My "Adventure Commuter Bonnie" got Scrambled up Cat_Daddy Twins Talk 6 06-03-2008 09:40 AM
My attempts at an Adventure Bonnie are nothing... Orpheus Twins Technical Talk 19 04-25-2008 07:12 PM
opening the airbox on '04 955 Daytona Deliberations 1 09-21-2004 05:18 PM
