Powerbronze Tail Tidy Installation Walk Through. - Triumph Forum: Triumph Rat Motorcycle Forums
Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints
Old 11-06-2007, 11:12 PM   #1 (permalink)
I'd like to start off by saying this project was incredibly fun, I had to cut wires, resolder, reshrink-wrap, and use most of my electrical, mechanical, and drafting skills to achieve this project.
I would like to state that if you attempt to use my walk through as a guide to do your own install from Powerbronze, I am in no way responsible for your screw ups.
In the beginning was the parasail:
By this I mean the GIGANTIC wing that is the license plate holder. We need to remove it...
1.) Remove the three mounting bolts that mount the rear fender to the underside of the bike.
2.) Disassemble the two parts of the fender so that you can unhook the 6 connectors that go to the tail light, license plate light and turn signals. Also disassemble the turn signals from the rest of the fender as you will need to dissect them for the stock connectors.
3.) Once the fender is fully detached and you're left with 6 connectors hanging off the back of the bike feel free to smash, crush, or stomp on the piece of junk you now have detached from the bike.
This is what you'll be left with hanging:
This is what you'll be left over with from disassembling the fender:
4.) Cut off the stock connectors for the brake light and turn signals, cut them off FROM THE LIGHTS THEMSELVES not the wire bundle still connected to the bike! Be sure to leave at least 2" on the connector end to allow for wire stripping and reattachment to the new parts.
5.) If you ordered the powerbronze turn signals like me, connect and heat shrink wrap the resistors to the turn signals ( this will seal them preventing moisture to short them out ).
CONTINUED BELOW:
7589 is offline   Reply With Quote
Old 11-06-2007, 11:13 PM   #2 (permalink)
6.) Cut off the ends of the male resistor wires as shown below, we will be soldering and heat shrink wrapping the stock connectors to these black and yellow wires, see below:
7.) Purchase a project box roughly 5" long X 2" tall x 2.5" wide from your local electronics store and drill two mounting holes and a third larger hole in the middle to mount the box to the underside of the tail tidy, this box will hold the ridiculously long wire mess we've made.
I also dismantled the tail tidy to carefully drill the two same size holes for the box mounting nuts and bolts and two small holes on the front face of the box for the turn signal wires to enter, see pics below:
CONTINUED BELOW:
Old 11-06-2007, 11:14 PM   #3 (permalink)
Pictures:
8.) Once you've resoldered the stock connectors onto the new powerbronze wires you're ready to bundle everything up and pack it all into the project box nice and neat.
9.) Carefully pack all the wires into the box and make sure the 2 wires for each turn signal are in the drilled hole slots, so that the box cover does not pinch them.
CONTINUED BELOW:
Old 11-06-2007, 11:16 PM   #4 (permalink)
10.) Turn bike on ( do not start the engine ) and test the functions of the turn signals, and the running light and brake light. When satisfied seal the box and enjoy!
Here are finished pictures of my installation:
Old 11-06-2007, 11:18 PM   #5 (permalink)
Please note that my turn signals DO NOT hit the hard bags. Your installation depending on the country you live in may differ.
Click Here For the Full Project Gallery
PLEASE NOTE IT IS A MYSPACE GALLERY AND YOU MUST LOG INTO MYSPACE
Questions? Comments? Please post!
--Kory
Old 11-06-2007, 11:27 PM   #6 (permalink)
HiddenSun's Avatar
Nice write up:... wish I could come up with some nice looking to keep the stocker taillight. I have replace the stock taillight with the stock looking one with the turnsignals built in. Just need to get rid of that nasty hang down.
'06 Sprint ST
HiddenSun is offline   Reply With Quote
Old 11-07-2007, 05:01 AM   #7 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Nice
Well done Kory and good pics.:
Very nicely documented with excellent photos in the style of OND in the tech blog section.
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 01-03-2009, 09:05 PM   #8 (permalink)
Favourite Bike: My 2008 Sprint ST
denoose's Avatar
Nice work, Kory- do you fancy a trip to snowy, cold New England to complete the same project on my new ST?
denoose
denoose is offline   Reply With Quote
Old 01-01-2010, 07:42 PM   #9 (permalink)
Newbie
Favourite Bike: Anything with two wheels
Other Motorcycle: 1980 Bonnie in pieces
looks great
The eliminator looks soooooo much better than the stock, I have a powerbronze hugger and now i am keen to get the eliminator. Thanks for the instructions and pics a great help.
des3234 is offline   Reply With Quote
Old 02-25-2010, 02:15 PM   #10 (permalink)
Newbie
Just fitted an R&G eliminator. It looks good but is a real fiddle. And I have a couple of complaints:
The tail light connector was too big to fit through the hole in the eliminator so that had to be enlarged.
There is a cover that fits at the back of the eliminator to provide so protection for the witing - it has two holes to take the wires from the indicators but I could not see how you could fit these through the holes and then connect them to the loom on the bike so I turned them into slots to take the wiring intact. The cover is not nearly as neat an affair as described above but the OEM was hardly water-proof.
The stock indicators touch the panniers - just.
We'll see how it fares. But I'm not sure that I'd recommend it that strongly to others.
Examiner is offline   Reply With Quote
Anyone use a Tail Tidy? Calliway Sprint Forum 24 01-03-2008 01:16 AM
Powerbronze Tail Tidy Install... 7589 Sprint Forum 10 11-07-2007 01:34 AM
Tail Tidy Shaunlee Speed Triple Forum 6 10-23-2007 04:46 PM
TAIL TIDY AVAILABLE SOON BUCKET Speed Triple Forum 2 03-07-2006 07:40 PM
My tail is now tidy... bwhip Sprint Forum 17 08-08-2005 10:03 AM
