Reset settings on ECU on Sagem Sprint: - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearHonda Powersports Motorcycle.comMotorcycle.com Classifieds!
Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints
Old 08-25-2007, 07:27 PM   #1 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Hi all,
this question comes up every now and then.
I had a talk to the very experienced Senior Triumph Tech that always works on my bike and this is how I was told it is done:
Start bike, preferably from cold.
DO NOT touch the throttle.
Allow the bike to idle until the cooling fan cuts in.
Once the fan is cut in wait a moment then switch off.
This allows the ECU to reset all the settings in it's tiny little head.
The reason not to touch the throttle is that the moment you touch it everything in the ECU changes.
The reason for leaving idling until the cooling fan cuts in is because the fan switching on is the last thing the sagem unit has to "sense" before doing it's own reset.
So if you try this and blip the throttle nothing will change.
So the wise man told me and I have no reason to doubt his word.
Apparently every now and then for some reasons the ECU gets a glitch in it and this resets it back to what it should be.
I did not ask about the 1050 engine, '05 onwards machines as you have the newer Kehin ECU and it will most likely be a different procedure for you.
Cheers,
DaveM:
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 08-25-2007, 08:16 PM   #2 (permalink)
oldndumb's Avatar
Realy, realy weird!?! I was thinking about this very same thing this a.m. as I cranked up for an early morning ride (not to beat the heat; to beat the rain).
Thanks. Good reminder.
Oldndumb
Caveat lector
Old 08-25-2007, 08:39 PM   #3 (permalink)
DaveM's Avatar
The Force
The force is strong with this one I see.
Reset your ECU you shall.
All settings will be RESET.
DaveM
My current album;
Old 08-25-2007, 10:29 PM   #4 (permalink)
Favourite Bike: 1999 Sprint ST
kc5deb's Avatar
To go past my fear of asking a dumb question, "just what exactly does doing this 'reset'?"
kc5deb is offline   Reply With Quote
Old 08-25-2007, 11:37 PM   #5 (permalink)
Thanks for info DaveM.
OnD, even with this drought, I managed to catch rain showers 5X in 3 rides this week. Last was today, got bike nice and clean from all recent rain riding and rode all day in the mountains. 10 minutes from home I get caught in a shower that lasts for maybe 1 mile. Felt good in the heat, but bike is slimed again from road spray. Such a good problem to have.
kc, not dumb at all. It's about the same as rebooting your computer. The ecu does as DaveM described, it gathers info from the various sensors and then uses this to control your engine. By allowing this "clean cycle" to run as described, the ECU will capture the "clean" data that will help the ECU perform it's job as designed/better than using partial "corrupted" data it may have stored from previous riding. Or as it was also explained to me, Computers run on Pure F'in Magic. If they run low on PFM, DaveM contacts OnD and sends him in with his Tune Boy Light Saber to fill the PFM back up so there is balance in the Universe. DaveM and OnD can do this as DaveM is tight with the BBMFIC.(don't ask).
Ride safe all.
Bob:
(DaveM, I'm liking these cigars, beer is good:, but could you round up some good sour mash whiskey to go with em? Thanks in advance)
bobw3592 is offline   Reply With Quote
Old 08-26-2007, 04:06 AM   #6 (permalink)
DaveM's Avatar
ECU light sabers, the force and magic!
Good enough for me Bob!::
Well described mate.
Like the man said kc5deb no dumb questions here.
If you don't ask you don't learn.......if you don't learn........well you get the general idea!:
DaveM
My current album;
Old 08-26-2007, 09:57 PM   #7 (permalink)
Anybody got any idea of how to reset on the newer generation 05 and up?
Brian
My Photo Album
remlin1 is offline   Reply With Quote
Old 08-26-2007, 11:31 PM   #8 (permalink)
ike9's Avatar
Thank you, thank you, thank you!
I performed most of my 24,000 mile, with the exception of fork oil renew and cam check. After renewing the air filter, my check engine light appeared (because of the operator not disconnecting the battery, and setting off a fault code). The bike ran fine afterwards, except for the annoying idiot light glaring at me from the cockpit.
I followed the SIMPLE instructions in this thread and bye-bye trouble light.
Thanks Again DaveM.
I have appended this as a note in my service manual for future reference!
ike9 is offline   Reply With Quote
Old 08-27-2007, 07:57 AM   #9 (permalink)
DaveM's Avatar
Glad
Hi Ike,
glad it was useful for you.
DaveM
My current album;
Old 08-27-2007, 11:11 AM   #10 (permalink)
cricket1's Avatar
DaveM;
Did you turn the bike off with the key, or the stop switch?
Does it matter?
'03 Sprint ST
Mods: 18T, Gen Mars, Heated Grips, SilverStars, Mufflectomy, Stebel Horn, Pazzo Levers, Corbin GF & L, SkyKing Sliders, NEP
cricket1 is offline   Reply With Quote
07 Sprint ST trip meter reset shoen Sprint Forum 4 10-17-2007 11:07 AM
F.I.Tuning all Sagem,Keihin. AndyMetric Maintenance & Workshop Talk 3 04-11-2007 12:58 AM
2000 sprint st computer reset (ignition sequence)? stwanted Sprint Forum 2 12-07-2006 01:48 AM
SAGEM or Keihin timoteusmunk Tiger Chat 2 10-02-2006 04:56 AM
'06 Sprint, trip meters won't reset? CLB Sprint Forum 5 05-28-2006 04:38 AM
