Sprint ST Aftermarket Part Numbers - 2nd Try - Triumph Forum: Triumph Rat Motorcycle Forums
Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints
Old 06-04-2006, 07:41 PM   #1 (permalink)
Favourite Bike: '08 Neon Blue Daytona 675
Panthers_Den's Avatar
Other Motorcycle: '02 Sprint ST (RIP)
Well it seems the first thread had 'issues' with the list and it's length so it was deleted. Unfortunately, it was done before I had a chance to save the data in the list :cry: So I'm recreating it again but this time I'm doing it under the Wiki Triumphrat Pages so that the length of the post won't make a difference (hopefully). And after playing around with it a bit, it seems like it'll be a much easier way to manage the list. If you guys wouldn't mind reposting your part numbers to this thread again, I'll see about re-adding it to the new list.
The new Part Number list is located on Wiki Triumphrat <- [Edit] old link no longer valid. use new link below.
Right now, there isn't much on there as I'm a little busy and my list of part numbers is located on a different system. But I'll update it with the part numbers that I actually have handy in a day or two.
Hey Don, could you re-sticky this thread so that the link would always be readily available?
Thanks
[ This message was edited by: Panthers_Den on 2006-06-04 23:42 ]
Update to the location of the parts number list:
Here's the link to the new page: Sprint ST after market part numbers
You can also get to it by going to the Blogs section, then clicking on technical data and then scrolling down till you see the posting.
:-D
'02 Sapphire Blue Sprint ST (RIP - Deer Victim)
My Photo Album - My Archived Photo Album
www.myspace.com/panthers_den
Last edited by Panthers_Den; 02-18-2008 at 10:46 AM. Reason: New link to the after market parts number page.
Panthers_Den is offline   Reply With Quote
Old 06-04-2006, 10:40 PM   #2 (permalink)
arrrgh!!!!!!
K, this is very kind of you PD.
Oil filters:
For Oz riders of 02-04 Sprints: Ryco claim their Z445 will work. Haven't tried it myself.
Honda "1 5410 mm9-013" said by a forum member also to work tho dimensions a bit different from stock
Protective tank film - no glue:
http://www.thetankslapper.biz/online...store/main.htm
Quality Australian made radiator guards:
www.radguard.com.au
Relays to run both headlights, courtesy of Welshrob: the relays you need are 4 pin 12 volt 40 amp with a resistor (6800 also works but doesn`t have the resistor) for surge protection. The common type in Australia are made by Narva and the part number is 68004.
[ This message was edited by: ST-ern on 2006-06-04 21:27 ]
Cheers, Ern
Motorcycle Sports Touring Club of Victoria, 50th anniversary year, Club website
ST-ern is offline   Reply With Quote
Old 06-05-2006, 12:16 AM   #3 (permalink)
Added them, thanks.
Old 06-06-2006, 12:19 AM   #4 (permalink)
Ok, I've updated the list to where it was when I created the first one plus some extra. I just need all the parts that everyone contributed to on the first list now :-D
Here's the link to the parts list again: Clicky
So if yall don't mind reposting your parts list, I'd appreciate it :-D
I'm also posting links to various manufacturers that make parts for Triumph Sprint ST's as well as sites that sell Triumph Sprint ST parts and other misc motorcycle parts.
Old 06-07-2006, 04:17 PM   #5 (permalink)
Updated again.
Old 06-09-2006, 05:32 PM   #6 (permalink)
Liftetime Premium
Favourite Bike: Grey 2010 K1300R - currnt
ruscook's Avatar
Other Motorcycle: Blue08 Tiger1050 - trade
Extra Motorcycle: White07 SpdTple - crashed
Hi Panthers_Den,
I just did my rear pads and put on GOLDfren 002's on the rear. These a sintered pads and feel fine (about 120K on them so far).
Do you do the wiki updates or do we add this info ourselves?
Thanks
Russ
ruscook is offline   Reply With Quote
Old 06-09-2006, 05:36 PM   #7 (permalink)
I've been doing the wiki updates. I'll go ahead and add those brake pads to the list real quick, thanks for the update.
Old 06-09-2006, 11:22 PM   #8 (permalink)
Liftetime Premium
ruscook's Avatar
No probs thanks. I have the GOLDfren catalog, so I'll look up the front pads as well. It seems the 05/06 use the same pads as th 02-04 and the Daytona 955s.
Russ
Old 06-09-2006, 11:24 PM   #9 (permalink)
I already posted the front brake pad's too. ;-)
Old 06-10-2006, 02:30 AM   #10 (permalink)
Liftetime Premium
ruscook's Avatar
Bloody mind reader :-)
Well done, and thanks
Russ
Part numbers ... ErricZTT Daytona Deliberations 11 09-20-2011 08:51 PM
Bearing part numbers kc5deb Sprint Forum 6 01-20-2008 10:57 PM
Where to get OEM part numbers rongway Sprint Forum 5 11-08-2007 03:55 AM
Part numbers seumas T3 Sport / Touring Forum 0 08-05-2007 12:27 PM
How to check part numbers: is it right? Sprint Forum 2 12-12-2004 08:38 PM
