Getting more adjustment from 1050 mirrors. - Triumph Forum: Triumph Rat Motorcycle Forums
Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints
Old 04-29-2006, 06:00 PM   #1 (permalink)
If you would like a bigger range of adjustment for your mirrors it can be done as follows:
1. Remove the 2 screws on the bottom of the mirror to remove the inner workings. You will want to be careful not to drop the glass. This will yeild a mirror attached to a pedestal.
There is a metal ring that must be carefully pried away from the pedestal until it's flush with the mirror base. Then the pedestal can be popped free from the mirror.
The next step is to grind/file sand a chamfer in the socket that holds the pedestal ball. I used a sanding drum in a grinder. The sanding drums can be had at anyplace that has Dremel tools or similar grinding tools for a couple of dollars. It could easily be used in a hand drill. It doesn't take much to remve enough material
Now pop the ball back in the socket and pry the metal ring back into place. Put it back in the mirror stalk and you're done.
By the way the metal clip on the back of the mirror might have something to do with how shaky your mirror is unless it's the whole mirror stalk that is vibrating.
[ This message was edited by: pinballjon on 2006-04-29 16:03 ]
pinballjon is offline   Reply With Quote
Old 02-14-2010, 11:43 PM   #2 (permalink)
Favourite Bike: Sprint ST 1050
Even easier way to increase mirror adjustment
The was a great post. My view with the standard Sprint ST mirror was mostly me! Instead of grinding, just shave the cup with a utility knife. It only took 10 minutes per side. Thanks
paul
ego veho sic ego sum
rokkopaw is offline   Reply With Quote
Do the mirrors fold in on the 07 Sprint 1050 whoosh Sprint Forum 4 08-02-2007 11:11 AM
Rebound Damper Adjustment on the 05 ST 1050 sprinter_steve Sprint Forum 8 06-16-2007 11:27 PM
1050 Mirrors RedBird Tiger Chat 3 04-08-2007 11:34 PM
1050 stock mirrors 9264 Speed Triple Forum 5 03-29-2007 12:22 PM
1050 SPEED TRIPLE BAR END MIRRORS geordiesas Speed Triple Forum 3 08-08-2005 09:56 PM
