Healtech gear indicator fittng guide. - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!
Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints DO NOT POST YOUR QUESTIONS HERE!! Please post questions to the general forum.
Old 02-13-2011, 03:47 PM   #1 (permalink)
Main Motorcycle: Aprilia RSV 4
Hi guy's just finished fitting my gear indicator so thought i'd share it with you.
I went for the healtech, model GPDS-T01.
Its quite easy on the sprint st 1050 main plug of the unit just plugs straight in to the diagnostic connector in the glove box.
Tricky part is connecting the +12v power lead.
The instructions say to fit it to a +12v power supply which is switched on only when the engine stop switch is in the run position.
They suggest...... ' you will find such a wire in the extension plug for the optional alarm, hot wire of the licence plate light or at the fuse box '.
I couldn't find the alarm plug, took the tank off to have a look, i believe it is under there somewhere, but drew a blank.
I decided to think about what is needed and apply a bit of logic to tackle it my own way.
+12v power supply that needs to be switched on and off with the ignition but also be turned off when you hit the kill switch.
With the ignition turned on but the engine not running i noticed that if you hit the kill switch the instruments all go out but the lights stay on.
So i decided that i would have a look at the wires from the kill switch and traced them back to a block connector.
I attached a length of black wire that i had left over from another job just to make things a bit easier.
Here's a few pic's
Disconnect plug and pull it out from above for easier access.
Red wire shown in photo is the one i spliced into.
Soldered my extra wire and joined them both back together then heat shrunk them.
Taped the loom back up nice and tidy.
Soldered and heat shrunk my extra wire together with the +12v from the healtech.
Finished photo,
I mounted it here in the end, thought about the clock surrond, but didn't fancy it.
Happy fettling guy's.......
Botch is offline   Reply With Quote
Old 02-23-2011, 01:01 PM   #2 (permalink)
Very nice...thanks for sharing! That's one of the mods I need to get around to doing.
GGG_ST1050 is offline   Reply With Quote
Old 02-24-2011, 11:26 AM   #3 (permalink)
Thanks mate....... hope it helps.
Old 03-02-2011, 06:01 AM   #4 (permalink)
Main Motorcycle: The new Tiger!
Other Motorcycle: 05 Sprint
Just ordered one of these and wanted to thank you for your write up.
I am curious though, can the brightness be changed? Also, how in the world does the unit determine the RPM's when it's connected to your headlight wire?
FutureTigerOwnr is offline   Reply With Quote
Old 03-03-2011, 09:16 PM   #5 (permalink)
Main Motorcycle: 2007 Sprint ST 1050
Walknbos's Avatar
Other Motorcycle: Early Katana 550M
Gear Indicator
I have one of these installed also - the splice into the light - I came up with the same solution - powers the LED - best to have a switched source working with the key - the RPM is read from the diagnostic port in the glove box - just plug it in - it's plug-n-play - except for the simple set up to allow the unit to learn the shift points - works like a charm. Hope this helps - installed on a 2007 Sprint ST
Walknbos is offline   Reply With Quote
Old 03-05-2011, 06:21 PM   #6 (permalink)
So I installed my heal tech gear indicator, configured it and two days later the very top crystal "went out" it doesn't light up anymore I'm a bit upset but will have it replaced under warranty. Has anyone else ever had a LED crystal "burn out" on their unit?
Installation was very easy, thanks to the OP's tutorial, so thank you!
--FTO
Old 03-07-2011, 06:45 AM   #7 (permalink)
So that top crystal started working again... odd.
Not sure if I should trust it or just have it all replaced.
Old 03-07-2011, 11:17 AM   #8 (permalink)
Main Motorcycle: All
pmorritt's Avatar
Other Motorcycle: '05 Ducati 999
Its a nice to have thing, all my old beemers had 'em. But after a few months got used to her and now see that at 70mph its at 4k and theres not another gear.
2009 Sprint ST Pacific Blue
pmorritt is offline   Reply With Quote
Old 03-16-2011, 08:47 AM   #9 (permalink)
So, on the 2011 Sprint GT I cannot find the plug mentioned above that connects to the kill switch to use for the switched 12v power source. Any suggestions for alternatives? Can I take a wire off of one of the two fuse boxes?
brselman
brselman is offline   Reply With Quote
Old 03-16-2011, 06:42 PM   #10 (permalink)
Main Motorcycle: 2005 Sprint ST1050 ABS
147sprint's Avatar
I connected mine to the parking light wire. I know its still live when the kill switch is off but I never leave the bike with the kill switch off and the ignition on anyway. Also I have never left the bike with the parking light on either so its not an issue for me.
147sprint is offline   Reply With Quote
Gear Indicator Poenster Speed Triple Forum 8 11-16-2010 03:05 AM
Any one got a Gear indicator grizzly adams The Rocket Science Forum 29 04-05-2010 03:51 PM
Gear Indicator rob-cyn Triumph SuperSports 9 06-01-2007 12:29 PM
Gear indicator Jacsje Speed Triple Forum 9 05-16-2007 03:43 PM
Gear indicator, why not? trumppa Speed Triple Forum 20 08-23-2006 04:52 PM
