| Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints
DO NOT POST YOUR QUESTIONS HERE!!
Please post questions to the general forum. |
12-10-2010, 02:24 PM
Site Supporter SuperSport Main Motorcycle: 2006 Sprint ST ABS
Posts: 1,398 Extra Motorcycle: 1973 Yamaha RD350
Sprint Forks Maintenance and Upgrade – Oil, Seals, Bushings, Springs & Gold Valves
This post describes the work I did to upgrade the suspension on my ‘06 Sprint ST. I hope my photos and description will help others who want to maintain or upgrade or simply enlighten those who are curious about what’s inside their forks. This information does not apply to pre-’05 Sprints that use old-style damping rod forks. For more photos check my album.
There are several alternatives available for upgrading Sprint suspension. I’ll review the various options in a separate post and focus on the maintenance tasks in this post. To upgrade my forks I used new straight rate springs and revised the damping by replacing the compression and rebound valves with Race Tech Gold Valves. I also replaced the bushings (Teflon-coated bearings) and seals. While the forks were removed I took the opportunity to inspect, clean and lube the steering head bearings too.
Rebuilding Sprint forks is not difficult but does require more than just basic levels of skill and experience. I would recommend having a manual to hand. For coverage of suspension maintenance I consider the Haynes manual superior to the factory manual. I’ve broken the description into sections so even if you’re not doing a full rebuild there should be enough information to help with each of the following operations: - Fork oil change
- Replace springs
- Upgrade with Race Tech Gold Valves
- Install new bushings and seals
Tools required
For fork overhaul your selection of tools should include the following: - 24mm wrench or socket for fork caps.
- Leak-free tray for collecting/cleaning parts.
- Torque wrench.
- Bushing/seal driver (or suitably-sized piece of pipe).
- Fork oil level tool.
Tools required for installing Race Tech Gold Valves are listed in the instructions for the valves.
Replacement Parts- Fork Dust Seals - Triumph Part # T2046234 (if replacing)
- Fork Oil Seals - Triumph Part # T2046232 (if replacing)
- Fork Bushings, Outer - Triumph Part # T2042889 (if replacing)
- Fork Bushings, Inner - Triumph Part listing not available (if replacing)
- Sealing Washer for Damping Cylinder Bolt - Triumph Part # T2042907 (optional)
- Fork Cap O-Rings - Triumph Part # T2042905 (optional)
- Preload Adjuster O-Rings - Triumph Part # T2042933 (optional)
- Fork Springs (for upgrade)
- Race Tech Gold Valves (for upgrade)
Consumables- Plenty of Paper Towels
- Kerosene (Paraffin) or Cleaning Solvent
- Suspension Fluid
- Grease for Seals (if dismantling forks)
- Loctite 271 – Red
- Plastic Bag or PVC Electrical Tape to put over end of fork tube to protect seals (if dismantling forks)
1 - Remove Forks- All of the tasks described were performed with the forks removed. The forks can be removed with the fairing in place but removal is a good precaution to reduce the chance of damage.
- Before removing the forks I loosened the fork caps. The fork caps mark very easily, as I discovered on a previous occasion, so I wrapped some masking tape around the hex before using a socket.
- In the base of the fork leg there is a bolt that holds the damper cartridge in place. It doesn’t need to be touched for oil change or spring replacement but I planned to completely dismantle the forks. To make it easier to remove later I loosened the damper cylinder bolt slightly while the fork was still held in place.
- After loosening the bolts on the bottom triple clamp, top triple clamp and handlebar the fork leg pulled out with a little bit of twisting.
2 - Remove Spring and Drain Oil- With one fork on the bench I unscrewed the fork cap. There is some spring preload tension but minimal force pushing on the cap when it’s released.
- The cap is held on the damping rod by a locknut screwed against the preload adjuster. To loosen the locknut I screwed in the preload adjuster to expose the flats on the threaded end of the adjuster. With a pair of 14mm wrenches I undid the locknut & removed the fork cap/pre-load adjuster from the damping rod.
- The spring is held in place by a cupped washer. A slot in the washer allows it to be removed from the damping rod. I lifted out the spring slowly to allow oil to drain from it.
- I poured the oil out of the fork tube into a container, pumping the damping rod a few times to help oil flow out of the cartridge. I inspected the oil for any debris that could indicate excess wear and/or damage that should be investigated during strip down of the forks and damping cartridge.
- The following sections describe work to the damper cartridge and replacement of bushings and seals. If the aim is to simply change fork oil or replace springs then skip these tasks and jump to Section 8.
3 - Remove Damper Cartridge- My next step was to remove the damper cartridge. I removed the bolt, loosened earlier, from the bottom of the fork leg and lifted the cartridge from the fork. The bolt came out easily without the need for a cartridge holding tool.
- It is recommended that the cartridge and valves are stripped and cleaned. If you are not comfortable with that and simply want to replace bushings and seals then make sure the cartridge is cleaned thoroughly before moving on to fork dismantle in Section 5.
Damper cartridge removed from fork tube.
Contd…..
Champ87
It's amazing how fast you can go when you take your time.
12-10-2010, 03:04 PM
…..contd.
Champ87
12-10-2010, 03:05 PM
…..contd.
Champ87
12-10-2010, 03:10 PM
…..contd.
6 - Install Damper Cartridge- I gave the damper cartridge a final inspection to make sure everything was spotlessly clean then lowered the cartridge into the fork tube. The bolt that fits through the bottom of the fork leg was refitted to hold the damper cartridge in place. A new sealing washer was used and the holding bolt tightened to the specified torque of 24 Nm. Those sealing washers can be re-used without problem but they are so cheap I replaced them just to be sure.
7 - Spring Preload Spacer- With new springs it was necessary to measure and cut the spring spacer to the required length. The aim was to achieve minimum preload of 15mm. To avoid mistakes I decided to use a piece of plastic pipe to make a trial spacer before cutting the aluminum spacer provided with the springs.
- Sprint damper cartridges have an external top out spring. For this type the recommended method is to place the spring inside the fork tube and take a direct measurement. I put a washer, the spring, another washer and my temporary spacer into the fork tube. I extended the fork then placed a mark on the spacer to correspond with the top edge of the fork tube. From this I needed to deduct the fork cap height. With the preload adjuster backed out I measured from the top lip to the point where the spring touches the underside of the original cupped washer. I added 15mm to give the required minimum preload.
- With my dimension confirmed I cut my temporary spacer and placed the parts onto the damping rod in order. With the fork extended I checked that I would have the recommended 15mm preload once the fork cap was screwed in place.
- Using my temporary spacer as a template I cut the permanent aluminum spacer to the correct length. In my case a spacer length of 85mm was required to give 15mm preload with the preload adjuster backed out.
8 - Refill Fork Oil (Suspension Fluid)
For standard springs the oil level is set at 120mm from the top of the fork tube with the spring removed and fork fully compressed. That requires approx. 469 cc of oil per leg. The factory manual lists Showa SS8, classified as a 10W oil. I previously used Bel-Ray 10W Fork Oil that seemed to provide the same damping as the original.
For my setup with Race Tech Gold Valves I used RaceTech Ultra Slick US 1 suspension fluid as recommended and supplied by them (well what else are they going to recommend?) RaceTech US 1 is labeled as 2.5 – 5 wt, a much lower viscosity than standard. - With the spring removed I filled the fork with oil. To distribute the oil I held my hand over the fork tube opening and compressed the fork. The pressure in the upper chamber helps oil flow through the cartridge. Bleeding was completed by lifting the damper rod a few times to make sure there were no air pockets in the cartridge. Oil level can measured with a simple dipstick or adjusted with a proper tool. I used a Mityvac vacuum pump configured to measure the correct level and draw out excess oil. I set my oil at the level recommended by Race Tech as part of the Digital Valving Search used earlier to for shim stack configuration and settings.
- Standard springs are placed with the close wound coils at bottom. I fitted my new spring with a washer at each end then the spacer. Using hand pressure to compress the spring slightly I slipped the original cupped washer onto the damping rod under the locknut.
- The locknut must be set to 10.5mm from the top of the damper rod - the height specified in the manual. With the correct height set I screwed the fork cap down and tightened the preload adjuster against the locknut.
- Before installing the fork cap I fitted new O-rings to the cap and preload adjuster. This is optional but I’d already bought new seals just in case the old ones weren’t in satisfactory condition. The fork cap is tightened to a torque setting of 25Nm.
- I refitted the plastic stone guard to the fork leg and repeated the whole operation for the other fork.
- When refitting the fork legs I tightened the bolts for the bottom clamp only. I refitted the wheel and axle but before tightening the remaining bolts I pushed down on the front suspension a few times to allow everything to align. To help the triple clamps align I loosened the headstock nut slightly. After bouncing the forks, I retightened it to the specified torque then the bolts on the top triple-clamp and the two axle clamp bolts.
9 - Setting up Suspension- With everything re-assembled I set preload to give correct sag. This link provides information on how to set sag so there’s no need for me to repeat it here. If you regularly ride with luggage or a passenger it’s a good idea to also check static sag in that configuration. Make a note of the settings so adjustment can be made quickly when needed.
- With these changes I will need to check headlight adjustment. Read this article for more information. In theory there should be no change if static sag is set to the same level it was previously but it would make sense to check.
Riding Impressions
Unfortunately cold weather has got in the way of any objective assessment of how the bike performs with these upgrades. I will post my thoughts later once I've had a chance to properly evaluate the changes.
More Information
Race Tech’s Motorcycle Suspension Bible is a superb resource for anyone who wants to know more about motorcycle suspension. It’s not Sprint specific but there is so much useful information in there that will be useful to novices and experienced alike.
Champ87
12-10-2010, 04:54 PM
Formula Extreme Main Motorcycle: 06 Sprint ST 1050 ABS
Posts: 703 Other Motorcycle: 91 Suzuki Katana 600
Wow. Fantastic write-up Champ!! Thank you VERY much.
12-10-2010, 06:09 PM
Site Supporter Powerbike
Thanks for taking the time to put together such a nice tutorial, Job well done.
Tmod
The Best You've Ridden Is The Best You Know
12-15-2010, 01:04 PM
Site Supporter Commentator Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
Posts: 9,035 Other Motorcycle: 05SV1K, 2012 Ducati M1100
Beeyoutifully done!
But then, that is what we have come to expect of your posts.
Oldndumb
Caveat lector
12-15-2010, 03:01 PM
Grand Prix 500 Main Motorcycle: 2007 Sprint ST ABS
WOW. Excellent write up. Well done and very timely for me, as I plan to tackle this project in the near future.
Your effort is very much appreciated.
Guinness is good for you!
12-15-2010, 03:13 PM
Site Supporter Supernova Main Motorcycle: 2011 Sprint GT 1050
Posts: 21,743 Other Motorcycle: 2004 Daytona 955 Extra Motorcycle: Previously - Many
+10
Thank you very much champ87 for such a well thought out and comprehensive thread on how to do this.
Great photos too.
Thank you and well done
cheers
DaveM
01-10-2011, 09:00 PM
Grand Prix 125 Main Motorcycle: Aprilia SXV550
Posts: 40 Other Motorcycle: Triumph Sprint ST Extra Motorcycle: Honda RC-51
Great write up. Serves well to remind people what they are paying for when they send their stuff out to a suspension shop or specialist to have their stuff worked on. Its a very detailed process and requires great attention to detail, other wise your forks can lock up on you and that is very unpleasant.
Never look down on someone unless you're picking them up.
NJ/NY/National EMT, CPR/BLS Instructor, SDI Diving 1st Aid Instructor
www.apexcpr.com
