upper & lower fork bushings, where to purchase: RACETECH, contact info and part #'s listed below
1999 – 2001 TRIUMPH Sprint ST & RS
SHOWA 43mm Diameter, conventional dampening rod fork.
• Fork Oil (USF05=5w, OSFO 10=10w, US2=10w, US3=15w),
Recommended Oil Level, 140mm, US3 2 qt/liter required, $30 per qt.
• Inner Fork Bushings (pair), FMBI 43151 P; $20 LOWER, Teflon on outside
Lower Bushing, Teflon on the outside, (smaller bushing)
dimensions: 14.8 mm (height); 43.5 mm (O.D); 41.7 mm (I.D.); 1 mm (thick),
• Outer Fork Bushings (pair), FMBO 43152 P; $22 UPPER, Teflon on inside
Upper Bushing, Teflon on the inside, (larger bushing)
• Fork Seals (pair) FSOS 43C P, $22
• Dust Seals (pair) FSDS 43 P, $20
Additional:
Highly recommended:
• Gold Valve Cartridge Emulator Kit (Damping Rod Type Forks)
RACE TECH part # FEGV S4301; $170
contact: RACETECH
http://www.race-tech.com/index.aspx
• Domestic Sales and Technical Information:
sales@racetech.com
• Information:
info@racetech.com
Phone: 951.279.6655
Extensions:
Sales - Michelle - ext. 122
Sales - Brad - ext. 111
Technical Support - Louie - ext. 109
1501 Pomona Road
Corona, CA 92880
