| Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints |
07-29-2009, 09:08 AM
Easiest Oil Change Ever!
I just changed the oil on my 09 Sprint ST. It was the easiest change I have ever done on a motorcycle. I bought a Honda oil filter wrench and filter, Mobil 1 oil, 20 minutes and it was done. No plastic to remove, no exhuast pipes to work your hands through.
07-31-2009, 05:58 PM
Site Supporter Formula Extreme Favourite Bike: all of them
Ken,
Piece-o-cake!
I always drain mine with the bike on the side-stand. After she is through dripping, I stand her straight up and then remove the filter.
I let her drip for a while straight up, then put her back on the side-stand, while shaking the bike, and more old oil runs out.
Good design!
08-10-2009, 06:32 PM
Site Supporter Formula Extreme Favourite Bike: Silver '06 Sprint ST1050
The longer you wait...
Originally Posted by WardenRoss
Ken,
Piece-o-cake!
Good design!
...same story here!
It took a short hour until the oil stopped dripping from the oil filter and drain plug holes. Raised the front tire with a piece of 1"x4", and stabilized the bike on the centre stand. Also alternated with side stand too. By the time it was all said and done, I got an extra cup of grungy oil out. Made me wonder why the gearbox and engine have cavities that don't allow direct drainage to the oil pan and filter openning...
I do all oil changes on our family vehicles, so didn't mind the wait at all. In the mean time, fussed around on the bike, cleaned the fairing, cleaned/lubed the chain, buffed the stainless and chrome, etc.
Wished I knew about SeaFoam then ( http://www.triumphrat.net/daytona-de...5-seafoam.html). Will consider using it or similar engine flash products in the next oil change. In the past I added a quart of diesel fuel to my PU's engine oil (while idling in the driveway) before an oil change.
Cheers.
08-28-2009, 03:42 PM
Minitwins Favourite Bike: bsa gold star db32
oil change
Originally Posted by kobywan99
...same story here!
Cheers.
Sounds good method of oil change, i have oil filter for sprint st 01 cost £9.00!! and saving up for mobil oil £37.00 .have oil change strap made of chain but some say can damage filter. wrench be better?
08-28-2009, 06:29 PM
Super Daffy Moderator
Site Supporter Nova Favourite Bike: 2011 Sprint GT 1050
Posts: 17,644 Other Motorcycle: 2004 Daytona 955
sobrien4,
seeing as you only use a filter strap for oil filter removal it doesn't matter if the filter is damaged.
New filters should only ever be tightened by hand.
DaveM
09-03-2009, 02:51 PM
oil change
Originally Posted by DaveM
sobrien4,
DaveM
Thanks for advice .just done filter and oil.brought a universal tool to remove filter £8.00.useless removed it but damaged sump ,just a scratch but annoying.might invest in triumph wrench £15.00 next time.used to overun in nuetral but put mobil 4t racing oil in and revs seem to have dropped am i imagening this ??
09-24-2009, 07:32 PM
Grand Prix 500 Favourite Bike: 2007 Sprint ST ABS
just did an oil change on my '07 today, and it was easier than on my previous bike..... which had no lower body work!
Triumph got this right!
a friend with an Aprilia Futura (dry sump, removal of body work, etc.) stopped by while I was finishing up.... needless to say he was jealous.
Guinness is good for you!
12-05-2009, 10:31 PM
Grand Prix 125 Favourite Bike: '08 Sprint ST ABS
Break-in Oil Changes
Trying to break-in my new '08 Sprint "by the book" and have a question...some recommend the first oil/filter change after about the first 200 miles then again at the "recommended" 500-mile mark. Waste of money or engine life extender? Thanks.
12-05-2009, 10:42 PM
Powerbike Favourite Bike: '04 Sprint ST
Posts: 342 Other Motorcycle: '98 T-Bird (totalled) Extra Motorcycle: '66 Trophy 650 (1st bike)
Change it at 500 and then stick to the recommended intervals. An oil change at 200 miles is a waste of $.
12-06-2009, 06:30 AM
On every 4 stroke motorcycle I have ever owned including both my Triumph Triples I change the oil twice as often as the manual states.
It has resulted in my bikes giving me very long engine life.
But that is just my habit.
DaveM
