MFW Peg Install Instructions - Triumph Forum: Triumph Rat Motorcycle Forums
Maintenance Tips and Tricks for your Sprint Maintenance tips, tricks, performance suggestions and proven setups for the Sprints
Old 05-13-2009, 10:23 PM   #1 (permalink)
Favourite Bike: all of them
How To Install MFW Foot Pegs
Disclaimer
I am not a mechanic, just a poor-soul trying to get by cheap. My instructions may not include the correct language or proper descriptions of the parts and mechanical devices. I learn simply by trial and error and call-it-as-I-see-it. That said; follow my instructions at your own risk! Cheers!
Shifter Side
1. Remove the small circular wire-retaining clip securing the front ball joint at the forward end of the shifter rod. Take note of how the clip is positioned for the reinstall.
2. Push the front ball joint off the pivot ball. You may have to loosen the Allen bolts holding on the foot peg assembly to allow the ball joint to swing free.
3. Remove the above-mentioned Allen bolts. The foot peg assembly can now be removed as you pull the shifter rod though the opening in the bike’s frame toward the rear of the bike.
4. Remove the shift lever from the back of the foot peg assembly by removing the Allen head bolt. You will need to place the assembly in a vice as the Allen head bolt is secured with super lock-tight. I used vise grips on the garage floor on a wooden block.
5. Now you can remove the factory foot peg by first removing the circular clip at the bottom of the pivot pin and then driving out the retaining pin at the top with a 9/32 punch. Don’t loose the small retaining pin! Now pull out the pivot pin that holds the foot peg. The foot peg return spring may give you a little trouble as it catches on the groove at the top of the pivot pin.
6. Install the new foot peg making sure to align the spring properly as you slide in the pivot pin. Reinstall and drive in the small retaining (top) pin and install the bottom circular clip. Make sure you have not installed the new foot peg upside down! The bottom of the new foot peg has an indention (stop) that goes downward.
7. Reinstall the shift lever to the inside of the assembly using blue lock-tight. I would add waterproof grease to the shaft before reinstalling it.
8. Before you reinstall the assembly, you will want to run the shifter rod out to the max length. Note the nuts have left handed threads. You may want to use a bench vise to secure the rod. I used vise grips on the garage floor with a wooden block. The nuts on the shaft may have super lock-tight applied so use caution loosening the nuts.
9. Reinstall the assembly but only start the Allen bolts so as to allow the front ball joint room to squeeze by the counter shaft cover. Grease the ball joint with waterproof grease. Pop on the front ball joint. Reinstall the wire clip (there is a miniature hole that the wire goes through). Tighten the Allen bolts to 27 Nm.
10. Set the new foot peg to the desired position. After you test ride the bike, and decide on the right position for you, I would recommend adding blue lock tight to the bolts and tighten them per the manufacturer’s instructions. THE END.
Brake Side
1. Remove the retaining clip at the bottom of the master cylinder brake rod that connects the rod to the brake lever. You can do this with only your fingers. Then remove the pin.
2. Remove the Allen bolts that secure the foot peg assembly to the frame. Now remove the assembly.
3. Remove the brake lever return spring. Now remove the brake lever from the back of the assembly by removing the Allen bolt that secures it. You will need to place the assembly in a vice as the Allen head bolt is secured with super lock-tight. I used vise grips on the garage floor on a wooden block.
4. Now you can remove the factory foot peg by first removing the circular clip at the bottom of the pivot pin and then driving out the retaining pin at the top with a 9/32 punch. Don’t loose the small retaining pin! Now pull out the pivot pin that holds the foot peg. The foot peg return spring may give you a little trouble as it catches on the groove at the top of the pivot pin.
5. Install the new foot peg making sure to align the spring properly as you slide in the pivot pin. Reinstall and drive in the small retaining (top) pin and install the bottom circular clip. Make sure you have not installed the new foot peg upside down! The bottom of the new foot peg has an indention (stop) that goes downward.
6. Reinstall the brake lever to the back of the foot peg assembly using blue lock tight on the Allen bolt. I would also grease the shaft with waterproof grease. Re-hook the return spring.
7. Reinstall the foot peg assembly to the bike. Tighten the Allen head bolts to 27 Nm.
8. Reconnect the brake rod, pin and clip and adjust it by loosening the lock nut then turning the rod to lower the brake lever. It will take some trial and error to get the brake lever where you want it. Be sure to tighten the lock nut.
9. Set the new foot peg to the desired position. After you test ride the bike, and decide on the right position for you, I would recommend adding blue lock tight to the bolts and tighten them per the manufacturer’s instructions. THE END
WardenRoss is offline   Reply With Quote
Old 05-13-2009, 10:50 PM   #2 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
Well done Warden. Great post!
Calliway is offline   Reply With Quote
Old 05-13-2009, 11:56 PM   #3 (permalink)
Lino's Avatar
Other Motorcycle: sold
nice work.. now I have to try those
Lino is offline   Reply With Quote
Old 05-14-2009, 07:22 AM   #4 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Great post WardenRoss:
How about we leave this thread here for a bit then I will move it into the tips and tricks subforum?
Wotcha Think Donski?
Cheers
DaveM:
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 05-14-2009, 08:34 AM   #5 (permalink)
Cheers
DaveM:
Sure Dave,
My thoughts exactly.
When I have the time I may dismantle the pegs and make some pictures to go with the instructions.
I hope the instrutions are clear enough not to need pictures though.
Thanks for letting it stay for a short while on the "front page." This way some of the more experienced members can comment and help me edit and improve the instructions. Plus it saves a lot of PMs and me repeating information.
Old 05-14-2009, 05:31 PM   #6 (permalink)
DaveM's Avatar
OK
would some one else like to add some helpful comments here before Don & I put this thread into the MT & sub forum?
DaveM
My current album;
Old 05-16-2009, 11:30 AM   #7 (permalink)
Favourite Bike: 2007 Sprint St
BigFrank's Avatar
Thumbs up
Nicely done Warden! Look forward to your report form the twisties.:
If you're not having fun, you're not doing it right.
BigFrank is offline   Reply With Quote
Old 07-10-2009, 11:05 PM   #8 (permalink)
If you find that after adjusting the shifter adjusting rod, the actual shift lever is still not low enough, you can move the clamp on the end of the shift shaft.
See the pix below. The clamp and shift shaft have factory locater dimples. Normally they would be aligned for assembly. You can loosen the clamp and move the clamp one notch clockwise. One notch will not adversely effect the normal leverage. One notch will lower the rubber (toe) end of the shift lever approximately one-half inch.
Old 07-28-2009, 12:54 PM   #9 (permalink)
Warden,
How have the new footpeg working out? Not to get too personel but what length displacement arm did you use and what is your heigth?
Thanks,
Brandon
brandon is offline   Reply With Quote
Old 07-31-2009, 06:13 PM   #10 (permalink)
Originally Posted by brandon View Post
Warden,
Thanks,
Brandon
By displacement arm are you referring to:
The mid piece on the MFW pegs?
or
The shifter rod?
The mid piece is 30mm and I didn't have to change the shifter rod. Just adjusted it out, and moved the shifter shaft clamp (per pix).
How about a 34" or so inseam with big feets!
I dearly love the pegs...BEST MONEY THAT I HAVE SPENT ON MY SPRINTY...PERIOD!
Clickie here for more info......
http://www.triumphrat.net/sprint-for...ower-pegs.html
ST 1050 luggage install -instructions? glebe74 Sprint Forum 20 06-04-2009 01:20 PM
Centerstand Install Instructions? queenpdog Twins Technical Talk 6 04-02-2008 07:40 PM
TOR is in. Install instructions please? TheNomad Sprint Forum 21 07-26-2007 03:53 PM
S3 Datatool alarm install instructions? rikroket Maintenance & Workshop Talk 1 03-30-2007 06:07 PM
anyone got turbo install instructions dmw777 The Rocket Science Forum 0 07-25-2006 01:45 AM
