| Maintenance Tips and Tricks for the T3 Classics Maintenance tips, tricks, performance suggestions and proven setups for the Hinckley Classic Triples. DO NOT POST YOUR QUESTIONS HERE!! |
12-11-2008, 05:38 PM
Site Supporter Team Owner Main Motorcycle: 99 Legend Sprint GT
Igniter remap & low cost stock replacement
I've been looking into this & posting on the 'Ignition Timing' thread, but think what I've discovered merits a new thread...
Things are looking very good - whereas I thought I might have to do some mods to a unit & source & test it with a replacement custom ignition rotor (& perhaps offer a kit), I've discovered a unit which has pretty much everything we need & will work with our stock rotors.
The unit, Sparker TCIP-4 is made by a small Czech company called Ignitech
http://www.ignitech.cz/english/aindex.htm
Cost is about 130 euro plus an adapter cable, maybe $190 or so for a straight plug in replacement kit. RPM/Advance curve adjustable, if you want, via their supplied software, PC & (standard RS232) Serial Port
But, for those who want to do some mapping, the unit can take an input from a throttle position sensor (TPS) as-is, or manifold (vacuum) air pressure sensor with a little bit of circuitry to give the required signal. Thus a 10 by 10 point 'map' RPM vs TPS (or intake vacuum) of ignition advance can be set with linear interpolation between points.
Neat eh ?
I read through a long thread on a Ducati Monster forum of people who have fitted this unit on their bikes. A technician called Brad Black has also played quite a bit (with it on a Duc) & posted up his conclusions on the web. The unit seemed universally praised, reliable & plugged&played happily even for folks not of a very tech/electrical bent. One minor issue arose with a small, but consistent - so workable with - error reducing advance below (so safe) that set as rpm increases. I have an idea why this is the case & plan to ask them if this is still the case & can they fix it in their software. In any event, I plan to confirm settings with a timing light when I've got set up.
I downloaded the software & they have a bike type listing for a Triumph Tigra (Czech for 'Tiger' I think  ). I'm sure that all the T3s have the same ignition rotor & they have confirmed the unit's suitability for Tbird/Legend in an email to me. I need to send a photo of the ignitor connector block for him to confirm he can supply an adapter cable. (Looking at the those he has on the website I think he will be able to supply this.)
So...what remains is to figure out supply & fitment of a throttle position sensor OR inlet vacuum (MAP) sensor....
...if the latter, I gather what's needed is to take a pipe from each of the carb balance vacuum ports & collect at a plenum(box) very roughly 15cu inches in volume ~ say 2"x2"x4" in order to damp out oscillations & combine all 3 cylinders then connect to a sensor unit for conversion to electrical signal.
A TPS sensor might be a lot easier if some means can be found to connect it to the carb throttle shaft.
Any ideas here very welcome....
I understand that Bonnie's have a TPS/RPM mapped ignitor & have a TPS mounted on the side of one carb. Tho' ours don't have fitting point or access to the butterfly spindle on the outer carbs.
The attached pdf file shows Ignitech's 'default' map for the Tiger to show where this might be going. Stock RPM/advance for a Tiger runs from 5deg BTDC @ 1000rpm to 29degBTDC @ 6500 & above. It seems likely then that much higher advance could be applied to Tbirds at lower throttle/rpm points than stock igniter will give & improve power/efficiency/economy for beginning of acceleration & when cruising.
98 Tbird tank/seat, Sprint fairing, ZX7R forks+Racetech Gold Valves, 08 ZX6R shock, Alcon 6-pot, Ignitech+TPS, T'bike 3-1+Beowolf can, airbox mods/rejet, tubeless wheels, lots :) per mile.
12-11-2008, 06:23 PM
Site Supporter Pole Position Main Motorcycle: 1996 Thunderbird "Nessie"
Posts: 3,451 Other Motorcycle: 1973 Trump TR7RV "Loosie" Extra Motorcycle: 1968 BS 350 GTR "Smokie"
Umm, the Tiger is injected, right - and so is the Monster. SO, remind me why I need this??? I am still trying to understand why you guys are wanting to map CV steamers....
12-11-2008, 06:47 PM
No, older monsters carbed, but guys there also fitting to older Ducs. T3 tigers up to '99 (I think) were carbed, for one year had 885 with EFI then moved to 955i motor. Tiger refered to above was 885 carb model, slightly different cams to 'classics' ~ 85bhp.
The idea is that without TPS or vacuum input Triumph had to use a conservative straight rpm/advance curve to ensure no 'knock' in worst case, full 'load' conditions, losing optimal timing advance under part throttle conditions - where most of our bikes are run most of the time.
They obviously later saw value in doing this (& microprocessors of sufficient power became cheaper) when they developed the Bonneville. Yamaha also fitted TPS & mapped ignition to their XJ900S & likely many other bikes so fitted before manfucturers moved to full EFI systems.
Plus, this unit can simply be fitted as a direct replacement (without TPS input) with a stock 'default' map, should an igniter fail. Around $190 versus Triumph unit at $700 !
BTW, I have no financial or other connection with Ignitech
Reason: addendum
12-11-2008, 08:03 PM
Grand Prix 250 Main Motorcycle: TBS 98, only1 i have
Posts: 45 Other Motorcycle: Motorcycles
I'm tempted with idea. 1st of possibility to "control" timing. 2nd if in future i go change camshafts...
Seems there might be TPS option on FCR!?
sorry, i never learned English, even worse! i make errors writing mother language.
12-12-2008, 02:40 AM
Site Supporter Team Owner Main Motorcycle: 98 Thunderbird
Posts: 4,544 Other Motorcycle: 03 Speedmaster
Excellent work Mike, I am following this with interest. How cool would that be, to be able to mess around with advance curves on a PC.
12-12-2008, 04:56 PM
Yep, I like the idea on an FCR much better....
12-12-2008, 05:39 PM
Pole Position Main Motorcycle: '99 Legend / '98 TBS
Hmmm. I happen to have FCRs. Maybe I should give it a try.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
12-12-2008, 08:18 PM
But did your FCRs came with Throttle Position Sensor? This can be "easy way" advance with TPS. But vacuum advance isn't new thing either...
12-12-2008, 08:29 PM
The Triumph Triple Kit does not come with TPS.
12-13-2008, 03:11 AM
I noticed that in Triumph 3 FCR Kit doesn't include TPS. Maybe nobody asked
But if T-Bird with Sprint camshafts, isn't there any space to play with igniter? Slightly different advance? Rev. limiter?
