Horn - louder - softer - Triumph Forum: Triumph Rat Motorcycle Forums
Maintenance Tips and Tricks for the T3 Classics Maintenance tips, tricks, performance suggestions and proven setups for the Hinckley Classic Triples.
Old 11-07-2005, 09:28 AM   #1 (permalink)
On 2005-11-07 07:04, Rincewind wrote:
5. The horn sucks
Alex, replace that horn with a Fiamm low-tone, if you want it to fit under the cowbell cover. It is cheap and has a better tone, available in car parts accessory shops in the UK, probably USA as well.
:-D
Bob
My Photo Album
bobshields55 is offline   Reply With Quote
Old 11-07-2005, 10:15 AM   #2 (permalink)
Favourite Bike: Street Triple R
Rincewind's Avatar
Other Motorcycle: Savage
:-D
Thanks Bob - I replaced it with a Fiamm Freeway Blaster in 2003, if that's what you mean.
I had a concurrent issue with the horn not working properly at idle (strangled sound). This turned out to be battery related, and was resolved when the battery was replaced. The tech who did my scheduled service in 2004 replaced the battery, and also "changed a setting" on the horn which raised the sound a few octaves, but also made it quieter. If someone knows where you change the horn settings, I'd appreciate knowing cause I'd like to adjust it.
Rincewind is offline   Reply With Quote
Old 11-07-2005, 02:07 PM   #3 (permalink)
Slinky's Avatar
There is normally a small adjusting screw on the back of a horn. Sometimes it also has a locknut to secure it. You tune the horn by turning the screw very slightly in each direction, until you get the loudest note. A little adjustment makes a big difference and can even stop the horn sounding, if that happens just turn the screw back the opposite way.
Old 11-07-2005, 03:54 PM   #4 (permalink)
Rincewind's Avatar
Thanks Slinky. Bob PM'ed me the same info. I'll have to check that out.
EDIT: The horn is sounding like a proper Freeway Blaster now, with a few turns of the screw. Problem resolved. Thanks Bob & Slinky!
[ This message was edited by: Rincewind on 2005-11-08 05:29 ]
Old 11-27-2008, 11:33 PM   #5 (permalink)
Favourite Bike: moto guzzi sp1000
toller's Avatar
Other Motorcycle: triumph legend TT
Extra Motorcycle: KX80
the problem with low tone at idle speeds is electric, but not the battery's fault. what you need is a relay. The stock horn does not draw much voltage, so it will operate with its blatt with the lower voltage that runs through the harness and through the ignition switch. The relay allows current directly from the battery to make that huge noise you're looking for, even when at idle or yet to start. they can be a bit of a pain to install if you've never done it, but ultimately anyone can do it.
I mounted a 139db nautilus (see highly modified hinkleys). Painted it black so it wouldn't stand out too much. Much prefer the big sound!
toller
aka leo in saint louis
2001 Legend TT
1979 Moto Guzzi SP100
photos http://www.triumphrat.net/memberalbu...ry.php?cat=983
toller is offline   Reply With Quote
Want a louder horn... adg44 Sprint Forum 42 07-30-2008 12:46 PM
making clutch softer. kidkazi Twins Technical Talk 4 06-21-2007 12:26 AM
Anyone try a louder aftermarket horn? What brand? stwanted Sprint Forum 28 05-15-2007 06:41 PM
Softer Seat for Dad. Spanky Hinckley Classic Triples 9 09-09-2006 04:34 PM
horn gets louder if you rev up the gas DennisRa1 Tiger Workshop (archive) 7 08-08-2006 02:48 PM
