fix that Legend tail light lens before it disappears - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsNew BonnevilleSportbikeTrackGear
Maintenance Tips and Tricks for the T3 Classics Maintenance tips, tricks, performance suggestions and proven setups for the Hinckley Classic Triples.
Old 08-14-2008, 06:42 PM   #1 (permalink)
Favourite Bike: moto guzzi sp1000
toller's Avatar
Other Motorcycle: triumph legend TT
Extra Motorcycle: KX80
Tail light lenses on the legend tt are weak where the screw stem meets the lens and cracks easily allowing the body of the lens to fall off, leaving just the two screws and the red stem mounted by your now white tail lights.
Use some epoxy or epoxy and filler and make a fillet, a build up of epoxy material, where the stem meets the body of the lens. Now it will have to find some other weak spot to crack.
toller
aka leo in saint louis
2001 Legend TT
1979 Moto Guzzi SP100
photos http://www.triumphrat.net/memberalbu...ry.php?cat=983
toller is offline   Reply With Quote
Old 01-09-2009, 11:14 AM   #2 (permalink)
Favourite Bike: 99 Legend
jwolf's Avatar
Last fall I pulled off the tail light lens, and sure enough, it was cracked inside. The previous owner had epoxied it back together. So off to the dealer for another new part that previous owners had neglected to replace.
I'm thinking maybe a small rubber washer between the screw and the lens might help avoid the repeat cracking.
Other ideas welcomed.
Only a couple months till spring!
jwolf is online now   Reply With Quote
Old 01-09-2009, 10:33 PM   #3 (permalink)
toller's Avatar
I would suggest not replacing the lens until you figure out how to keep the old one from falling the rest of the way off. Try the washer, its not going to keep it from cracking but maybe the washer will extend to some firmer lens area that won't fall away. Its a design flaw. All I had left was two screws through two round plastic mount tubes. I used two red light bulb condoms over the white bulbs until my new lens was received.
You cannot tell it is repaired when creating an epoxy fillet repair from the inside.
Tell us of your results. Best of luck and ingenuity.
toller
2001 Legend TT
Old 01-16-2012, 07:19 PM   #4 (permalink)
Favourite Bike: Bonnie T-100 Creamsicle
drharveys's Avatar
Other Motorcycle: Suzuki Boulevard S-40
Extra Motorcycle: Thunderbird Triple--SoCal
Here's what I did with mine last week. I used two-part epoxy.
Before: (You can see how weak the tube is)
After: (I filled in the gap between the plastic ring and the tube, also attached the whole thing to the lens)
Every difference of opinion is not a difference of principle... Thomas Jefferson, Inaugural Address 1801
When I look fast, I'm not smooth and I am going slowly. And when I look slow, I am smooth and going fast. --Alain Prost
drharveys is offline   Reply With Quote
Clear Lens LED Stop/Tail with Integrated Indicators Wolf Speed Triple Forum 1 02-25-2008 05:55 PM
Clear Lens LED Stop/Tail with Integrated Indicators Wolf Sprint Forum 3 02-25-2008 05:25 PM
Tail light lens cover loose - how to fix? MotoRaider Speed Triple Forum 5 08-12-2007 11:45 PM
LEGEND TBIRD tail light wiring. Spyke Maintenance & Workshop Talk 3 12-19-2006 11:28 PM
Help needed! Tail light lens Leebo Sprint Forum 4 04-01-2005 11:32 AM
