Fuel leaks - Triumph Forum: Triumph Rat Motorcycle Forums
Maintenance Tips and Tricks for the T3 Classics Maintenance tips, tricks, performance suggestions and proven setups for the Hinckley Classic Triples.
Old 03-24-2008, 09:50 AM   #1 (permalink)
Fuel leaks
My 1998 TBS (8000 miles on clock) started idling on two cylinders when I was out for a ride this weekend. When I accelerated, all three kicked in and it cruised along fine. On the way home sitting at traffic lights, it was on two cyls and there was a strong fuel smell.
When I got home and put it up on the center stand in the garage, there was fuel streaming out of the airbox. I opened the stopper on the airbox overflow pipe and fuel poured out. The only way I could stop the flow was to turn off the fuel petcock.
Sounds like a carb float issue, but would welcome any clues/ideas/tips before I start tearing things apart.
Xcalibur is offline   Reply With Quote
Old 03-24-2008, 10:24 AM   #2 (permalink)
Favourite Bike: 95 TBIRD
patrol21's Avatar
yep....sound like floats....could be a couple of things
1) Toasted float.....got a crack in one and its sticking or for some reason it got itelf hung up. Either way, you'll know when you pull the carbs and open em up. If there is gas in one, toss it.
2) O-rings-there is an o-ring that seats into carb body where the float attaches. These go from time to time and if there is not a good seal, the gas getting by will end up in your airbox and continue to leak. I have a feeling this is your problem. Jimmy900 had a good replacement idea as you cannot buy these from Triumph...only the entire float assembly....expensive when o-rings are around a penny. Check the recent forums as I seem to remember a week or two ago, someone was having simlar issues.
The worst day riding beats the best day at work....no exceptions.
patrol21 is offline   Reply With Quote
Old 03-24-2008, 10:53 AM   #3 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
third option and quite likely is that you have dirty or worn needle vale seats
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 03-24-2008, 04:07 PM   #4 (permalink)
patrol21's Avatar
good point Mick, especially since he is having issues at Idle.....
Old 03-25-2008, 09:58 AM   #5 (permalink)
Carb Rebuild?
Hey lads,
Thanks for the pointers. Any ideas where I can get a carb rebuild kit for the Keihin CVK 36mm?
Old 03-25-2008, 10:20 AM   #6 (permalink)
KD5QOQ's Avatar
http://www.sudco.com/
http://www.sudco.com/keineevalset.html
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
KD5QOQ is offline   Reply With Quote
Old 03-25-2008, 04:26 PM   #7 (permalink)
Jimbo,
Thanks for the link to Sudco. What about the float bowl gaskets? Should I replace those, and if yes do Sudco do those as well?
Old 03-25-2008, 04:30 PM   #8 (permalink)
patrol21's Avatar
had my bowls off at least 20 times.......never had to replace the rubber gaskets. I have Mikuni's though, so not sure what the Keihens have.
Old 03-25-2008, 04:31 PM   #9 (permalink)
KD5QOQ's Avatar
More often than not you get away without replacing.
I did notice they are a little vague on our model carb.
For that reason I would call them with parts inquiries.
Good luck dude, you'll have her fixed in no time.
Jimbo
Kroger Plus Member
05YZ450F
89 CR500
Old 03-25-2008, 06:16 PM   #10 (permalink)
I am going to try draining the carb bowls first. Can this be done without removing the carbs?
Fuel Cap Leaks jawa150 Classic, Vintage & Veteran 4 10-23-2006 10:47 AM
Fuel leaks ST? kneedown Sprint Forum 5 08-25-2006 06:16 PM
fuel tank leaks & repair johnnypence Classic, Vintage & Veteran 12 06-20-2006 05:37 AM
O2 sensors and fuel leaks Timtiger Tiger Chat 14 09-22-2004 05:37 PM
New fuel fitting leaks. Jerry Sprint Forum 3 09-03-2004 05:00 PM
