It seems a good suggestion in the quote by Mienzio of the
ssevy tip to wrap the bleed nipple thread in teflon plumber's tape as air can get into the bleed nipple threads when bleeding if you open them too much when trying to gain initial pressure. It only needs a small turn of the bleed nipple to let fluid escape. I have never used tape that way but you have to be careful not to allow air into the bleed nipple threads otherwise you are totally wasting your time.
If you pump fluid into the bleed nipple to fill the master reservoir then make sure the top cover is on without being tightened down and protect with a rag around it for leaks otherwise you will spray fluid out of the reservoir.
I've also tried the overnight method of tying the brake lever to the bar and tapping the brake line and calliper but it's a hit and miss method.
Definitely using suction or pumping the fluid in is the fastest and surest way of getting air out of the system when you've lost all pressure in my experience.
....and I'm going to get myself a
ssevy syringe, it's better than the one I used.
Ride on !
