Instrument assembly plug - temp indicator problem - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-14-2005, 04:01 PM   #1 (permalink)
Where can this plug be located on a classic triple? I printed the service bulletin as I defininitley have this problem. Is it in the headlight assembly?
Jerry V. - Northern NJ
Jcatbert is offline   Reply With Quote
Old 04-18-2005, 02:57 PM   #2 (permalink)
Slinky's Avatar
Yes it is, there is one bunch of wires that runs down from under the idiot lights, and connects inside the headlight.
Old 04-18-2005, 02:57 PM   #3 (permalink)
Slinky's Avatar
Old 04-25-2005, 09:05 AM   #4 (permalink)
>Yes it is, there is one bunch of wires that runs down from >under the idiot lights, and connects inside the headlight.
Indeed I did find it. Problem was it did not match the documentation I had that was written for the Trophy. In any case, I still have a problem and will probably need to dig in and look for a short. My temp light is always on, even if I pull the wire off the sender. Presumably that means my sender wire must be shorted? I guess I need to trace the sender wire to the harness and try and see what's in between. I think I may need to unravel the bundle? Any other ideas? I'd hate to undo all that for nothing. Thanks!
Old 04-25-2005, 09:05 AM   #5 (permalink)
Old 04-25-2005, 02:38 PM   #6 (permalink)
Bret
To eliminate the temp sensor ground the temp sensor lead and see if the light goes off. I had a temp sensor fail on a Kawasaki - they can go bad.
If it does not go off when the lead is grounded check to see if there are any other components in series with the temp sensor - and go thru each one step by step.
This is why I say that. I recently had a starting problem with my '95 1200 - and the neutral light was staying on, even when in gear. I thought, okay problem with neutral swtich - but when I did the tests as stated in the Haynes manual (if you don't have the Haynes manual -get it - it has much more info than the factory offering - whcih for my bike had no electric sysstems tests at all) - I eliminated the neutral sensor as being the problem.
Turns out there was a loose or corroded connection to the solenoid - after I wored thru each component to see that they were all okay. The clutch switch and oil sensor are also in series with the neutral sensor, and they all share a common lead with the solenoid.
Unless the wiring harness housing your temp sensor wire was yanked or abused it seems unlikely that there would be a short in it - but simple to test with a ohm meter - obviously you should get continuity.
Hope it helps and good luck.
High-Beam Indicator Light Problem swish77 Twins Technical Talk 6 06-01-2008 10:40 PM
Turn Signal Indicator Relay Problem 02 Teknic Speed Triple Forum 2 10-09-2007 09:02 PM
indicator problem... JonCG Twins Technical Talk 4 08-01-2007 04:49 PM
Intergrated Brake Light Indicator Assembly Pugsley Sprint Forum 9 09-29-2005 08:32 PM
LED indicator cross talk problem karter257 Club Cafe' 6 07-08-2005 04:02 AM
