charging system - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-30-2005, 03:33 PM   #1 (permalink)
I have a 1993 trophy 1200 with21250miles on the clock the battery goes flat after about 5 days use of commuting to work ,I have fitted anew battery but still the same .put a volt meter across the battery it shows 12.75v at tickover is this normal?
Old 03-30-2005, 05:26 PM   #2 (permalink)
No, should be 13.5 ~14. My guess would be either your alternator or voltage regulator is bad.
stevent....."May the Goddess turn the hearts of those who hate us, if not their hearts then turn their ankles so we'll know them by their limping..."
stevent is offline   Reply With Quote
Old 03-30-2005, 05:40 PM   #3 (permalink)
You may also have something simple like a bad earth.
To check the alternator output (rather than the voltage across the battery terminal, trace the wires from the alternator and test here. You can put the voltmeter probes into the 2 pin connector. See what the voltage is at idle and also at 2-3,000RPM. Test this with the 2 pin plug connected. DO NOT disconnect this 2 pin connector. If you do this when the motor is running, you may fry the $800 stator!
If the voltages are different, you may have a wiring, earth, fuse problem.
Hate to deliver bad news, but there have been a few reports of bad alternators in this forum. I have had one myself on my 955 Tiger.
Good luck.
Timtiger is offline   Reply With Quote
Charging system? chukus13 Speed Triple Forum 1 03-29-2008 02:33 PM
Charging system m970456 Speed Triple Forum 1 03-16-2007 11:25 PM
Charging System tyrebyter Tiger Workshop (archive) 0 06-30-2006 08:17 AM
Charging system. jtrip Classic, Vintage & Veteran 1 11-07-2005 11:56 AM
charging system help! Trophy 5 04-01-2005 02:18 PM
