Baffled by baffles - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleSportbikeTrackGearHonda Powersports
Old 03-28-2005, 02:23 PM   #1 (permalink)
Favourite Bike: 1998 Thubderbird Sport
idahotb's Avatar
Other Motorcycle: 1996 Sprint
Extra Motorcycle: 1997 T595 Daytona
I know that 90% of the exhaust posts are on how to increase the sound of the pipes, but I want to do the opposite. I bought a used '96 Sprint 900 last year, that came with D&D slip ons. Now, I added the TORs to my TBS and really love the way they sound; but the D&Ds are LOUD! I am thinking of trying to make some kind of insert to temper them just a bit, but I have no real clue about designing exhaust systems.
I pulled the cans off the bike but haven't cracked them open yet. Looking in, there is a perforated sleeve the same diameter as the exhaust pipe that runs the length of the can. I am assuming that this just acts as an expansion chamber that reduces pressure and slows the exhaust velocity. Putting some sort of packing outside this would seem to be counter productive. I am contemplating loose packing the sleeve with some sort of material (loose fiberglass or course steel wool come to mind).
So my questions are:
1) If I am careful not to create too much back pressure can I screw anything up? (If anyone can, I can)
2) Has anyone else done anything similar? I am nuts to do this?
3) I am nuts to ever try this?
4) Any other suggestions or comments?
Thanks folks. You are a great resource.
I-da-ho
Speed is good. It is way better to be shot out of a cannon, than squeezed out of a tube. That is why God made motorcyles.
My album
idahotb is offline   Reply With Quote
Old 03-28-2005, 03:58 PM   #2 (permalink)
Favourite Bike: 1995 Thunderbird
SWare's Avatar
D&D pipes are notoriously loud.
Have you checked with them for a packing kit or some such?
Some of the sport bike silencers of other brands have them for when the packing starts to deteriorate. Maybe some of the material from one of those would work.
No hands on here just read about it or seen ads etc.
Stan
:brk: :razz:
SWare is offline   Reply With Quote
Old 03-28-2005, 06:15 PM   #3 (permalink)
A removeable baffle would be the thing.
Many manufacturers supply them with their exhausts for on and off road use.
They make a huge difference to the loudness.
davie.
I,ve got a mountain of dreams to climb.
Do unto others as they are doing unto you.
tango is offline   Reply With Quote
Old 03-28-2005, 09:58 PM   #4 (permalink)
Some of the guys over on the Twin forum have put baffles in their pipes to quiet them down a little....Heres a link to a post that has pretty good info, I'm sure the author could help you out.....
Baffle post
My Baby
Copper is offline   Reply With Quote
Old 03-28-2005, 09:58 PM   #5 (permalink)
Baffle post
My Baby
Old 03-31-2005, 07:42 PM   #6 (permalink)
Favourite Bike: 1968 Triumph Trophy TR6R
Other Motorcycle: 2012 Tiger 800XC
Extra Motorcycle: 2003 Bonneville T100
Idahotb, I started the thread to which Copper refered. I installed JC Whitney baffles in my adapters to tone down my BellaCorse Teardrops. Baffles can be purchased in different diamemter sizes. I do not know what diameter baffles you would need for D&Ds on your Sprint. Since you have pulled the mufflers, measure the diameter of your header pipes. You might be able to install baffles there. That is essentially what I did with my Bonnie. Read through the thread including 'Dweeb's comments. Feel free to ask me any questions.
Carl S
Old Soldier
CarlS is offline   Reply With Quote
Old 03-31-2005, 09:02 PM   #7 (permalink)
idahotb's Avatar
Carl- Did the baffles in the adapter make the bike run a little rich? Did you have to mess with the carbs?
Thanks to everyone else who responsed. I will take a look and let you know how it turns out..
Now pray for sunshine!
I-da-ho
My album
Old 04-01-2005, 06:20 PM   #8 (permalink)
I-da-ho,
Anytime that you change the exhaust flow, you will affect the mixture. Keep in mind that I have a Bonneville. When I installed the Teardrops, I rejetted to 130 mains. I did not change the pilots. I was a little lean at lower rpms and at midrange. Installing the baffles made it run a tad on the rich side; but not overly so. I did not rejet because I am going to install Thruxton needles and I will definitely have to rejet. I'll start with 115 mains with the Thrux needles. My guess is that without the Thrux needles and with baffles installed, I should be running 42 pilots and 128 mains.
Here's hoping you have good weather!!
Carl S
Old Soldier
Baffled by the baffle blackbird Twins Technical Talk 8 10-22-2007 09:55 AM
I'm baffled! idahotb T3 Sport / Touring Forum 10 05-15-2007 10:23 PM
newly un-baffled CaptJack Twins Technical Talk 0 05-07-2007 01:07 PM
TOR's vs. ex-baffled Stock Pipes zighawk Twins Talk 7 06-28-2005 01:52 AM
baffles seumas Maintenance & Workshop Talk 3 08-14-2004 09:28 PM
