Checked with Team triumph of Wisconsin, out of Janesville, Wi. They said 15 minutes for a new tune... hmmmm still not quite sure about the local dealer. Thanks for the input
On an open loop system, my 99 955 that has no feedback to the best of my knowledge, (O2 sensor) How does the ECM "recalibrate its response to sensor input"?
I would think that the sensors read and report to the ECM in the exact same fashion as they always have. Unless you change sensors, or alter the sensor output, And the ECM just applies the sensor output to the new map value.
Even if you did change the sensor output wouldn't the ECM just read the "altered" signal and try to repond to the new value instead of trying to recalibrate?
I have read that it is possible to reset the TPS zero but I would figure that once it is set the "recalibration" is done, and the ECM once again resumes normal function with the new zero value.
Or am I missing something significant?
We's a turn'n, we's a turn'n
