Site Supporter Formula Extreme Favourite Bike: Whatever I'm riding....
Posts: 717 Other Motorcycle: 07 Tiger ABS & 79 T140 Extra Motorcycle: 95 TB & 08 Ducati S4RS
If the head gasket is gone, or the head is cracked then there should be some pointers:
1) Coolant loss - is the coolant level going down?
2) If it is going down, where's it leaking to?
a) Is the engine oil emulsifying due to coolant ingress? Does it look whitish, especially round the oil filler? (water vapour condenses where it's cooler). You might consider draining the oil in a clean clear container, and looking for water settling out at the bottom.
b) If it's leaking into the cylinders you might notice that it's spitting more water than usual out of the exhaust? Note: check this with the engine warmed up as engines produce a lot more water when cold due to the rich mixture.
c) Does the coolant itself contain oil? Can you see bubbles appearing in it? Any sign of external leaks?
So, unless you are seeing one of these indicators, I would look for other possibilities.
Fan switch - is the fan coming on when it gets hot?
Temperature sender/sensor - if it's not too expensive just screw in a new one and see if the problem continues.
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
