Trouble with Shifting or Timing? - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsOntario TourismMotorcycle.comNew Bonneville
Old 03-21-2005, 08:24 PM   #1 (permalink)
Favourite Bike: 2000 Legend TT
CrazyCroc's Avatar
Well, I almost have my Legend back together after my minor dump a little while back. Was starting to get a little proud of myself because I was near completion on my first big job on a motorcycle, but now I've hit a snag ...
The original damage was done in a left side dump and I broke the shifter shaft. I read a few things where somebody hinted about going through the sump instead of splitting the crankcase, and said what the heck. I went through the sump, got the shaft out with no problems, and I replaced it with the new one and the quadrant is meshed properly with the gearchange drum.
But now here's the problem: It doesn't want to shift to the next gear smoothly. I had it elevated on stands for better access and the wheel had been turned (accidentally?) while in neutral. I don't know if this threw off some kind of timing or what. Now in order to shift to the next gear, I have to rotate the tire a bit (usually a few inches) until the next gear clicks in, and so on up through 5th. But then I have to do the same exact thing on the way back down to 1st.
The manual mentions gear line-up for four cylinders, but nothing about triples. Plus, I never actually removed any of the gears, linkage, clutch, etc. The only thing I pulled out was the shift shaft itself.
I've posted this in the Hinkley forum as well, to see what kind of replies I get there, in case you are curious about the results. My Hinkley Post
Thanks in advance for any help.
'Honey, I never drive faster than I can see, and besides that, it's all in the reflexes.' - Jack Burton, BTILC
my photobucket ...
CrazyCroc is offline   Reply With Quote
Cam Timing rickster Daytona Deliberations 5 08-11-2007 05:24 PM
1-2 Shifting Trouble Tritanium Speed Triple Forum 11 07-27-2006 11:30 PM
Timing question Kima Speed Triple Forum 1 02-12-2006 08:25 AM
timing musicman59 Classic, Vintage & Veteran 0 09-11-2005 08:08 PM
Trouble with Shifting or Timing? CrazyCroc Hinckley Classic Triples 4 03-22-2005 12:46 AM
