Battery hookup - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-17-2005, 06:10 PM   #1 (permalink)
Guys,
On my bike I have what looks like a male/female bullet quick connect for a battery tender of sorts, this is something new to me can anyone tell me what brand of battery tender I can hook up to this is?
Thanks!
Old 03-17-2005, 06:10 PM   #2 (permalink)
Guys,
Thanks!
Old 03-17-2005, 06:18 PM   #3 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
From your description is sounds like a "Battery Tender" battery tender. A picture would help enourmously
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 03-17-2005, 06:18 PM   #4 (permalink)
Mick...
Old 03-18-2005, 10:35 AM   #5 (permalink)
GaryD's Avatar
Are you certain its connected directly to the battery? My Battery Tender Plus connections have an attached cover plug to keep the contacts clean when the plus is not attached to the charger, does the plug on your bike have this cover?
[ This message was edited by: GaryD on 2005-03-18 08:36 ]
Unsafe at any speed. First Terranaut.
GaryD is offline   Reply With Quote
Old 03-18-2005, 11:13 AM   #6 (permalink)
Thanks for the reply guys,.
What I have is a thick wire running down the left side of the bike attached the to the rear peg, it has a plastic end cover, when you pull this off there is a male bullet connector and next to it a female bullet connector. I'll see if I can get a picture taken today.
Old 03-18-2005, 05:01 PM   #7 (permalink)
As I said, it's sounding just like a "Battery Tender" battery tender. The small harness connects directly to the battery has the connector like you describe (usually with an inline fuse 1/2 way between). A photo would provide +ve confirmation.
Mick...
Old 03-18-2005, 06:46 PM   #8 (permalink)
Favourite Bike: 2010 Bonneville T100
geezerx's Avatar
Other Motorcycle: gone
Sounds like the same thing as on my bike. It's wired as MickMaguire describes. "Battery Tender" battery tender plugs in no prob.
Good judgement comes from experience, and a lotta that comes from bad judgement.
- Cowboy Wisdom
geezerx is offline   Reply With Quote
Hookup of test tachometer Derby Boy Twins Technical Talk 7 12-25-2007 07:38 PM
garmin gps 550 hookup ricster Sprint Forum 12 08-10-2007 03:00 PM
Tach' hookup & eng' hiccup FattRat Twins Technical Talk 10 11-17-2006 12:40 PM
02 ST tank line hookup Q Stiles Maintenance & Workshop Talk 2 02-05-2006 04:30 PM
2002 SPEEDTRIPLE FUEL LINE HOOKUP TO TANK Maintenance & Workshop Talk 6 06-11-2005 09:07 AM
