Cam Chain - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-10-2007, 05:55 AM   #1 (permalink)
Unhappy Cam Chain
has anyone had trouble with the cam chain tensioners failing on the 900 motor
keep on trucking
truckie is offline   Reply With Quote
Old 11-10-2007, 12:15 PM   #2 (permalink)
Favourite Bike: ST 955 for now.....
GONE14S's Avatar
I just checked mine. There was some build up of grime around the latch assem. that locks the pluger in place. I cleaned it up reset the pluger and it snaped right back into place.
I would not recomend pulling the Cam Chain Ten. if you don't know the correct way of doing it. It's very easy to knock the cams and crank off timing while the chain is loose with the C.C.T out of the motor. Use a wood wedge between the slider and the block to keep the chain tight while the CCT is out of the motor. You will need to have the valve cover off the motor to do this.
Cool thing about it is that if the chain is wraped out of shape you can replace it without removing the motor or pulling the motor apart.
Good Luck..
Kurt
01 Sprint ST955
British racing green.
"To show fear is to lose control, To lose control is to make a mistake, To make a mistake is to lose the game. "
GONE14S is offline   Reply With Quote
Old 11-13-2007, 04:46 PM   #3 (permalink)
Favourite Bike: 95 Thunderbird; 96 Sprint
GeoffE's Avatar
Other Motorcycle: 82 Jota; 79 XS850
Extra Motorcycle: 72 BSA Rocket Three
Hi,
Yes I have had a cam chain tensioner fail. It is an automatic adjusting/ratchet design, but it did not adjust.
I have posted details of a manually adjustable tensioner previously, if you would like to do a search. Not a perfect (colour) match, but more reliable.
Ciao,
Geoff
GeoffE is online now   Reply With Quote
Cam Chain truckie Trophy 10 01-14-2008 04:41 PM
Cam Chain truckie Trophy 1 11-14-2007 03:22 PM
cam chain English_Spanner Twins Technical Talk 5 01-27-2007 01:59 PM
Cam Chain Tensioner johnny5 Triumph SuperSports 4 08-31-2005 04:36 PM
How long does a cam chain last? Slinky Hinckley Classic Triples 34 05-30-2005 01:53 PM
