no go - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-05-2007, 07:25 PM   #1 (permalink)
Unhappy no go
i have a 1996 900 trophy which was going fine but yesterday the engine just stopped while cruising, carbs have fuel, spark plugs have spark air filter is good,fuses are fine,also i did not bump the kill switch
keep on trucking
truckie is offline   Reply With Quote
Old 11-05-2007, 09:01 PM   #2 (permalink)
i took the timing cover over off and found the cam chain guide had broken off and jammed itself between the crank shaft sprocket and timing chain what parts will i have to buy ?
keep on trucking
