Your right it would be easier to just swap engines. I would at least need to swap shift cams to keep the 1 down 5 up pattern.
What makes you so sure the Tiger 955i has different cams?
The manuals list different specifications for the lift and timings for the 2. I'm not sure
how much difference it would make to the performance. Now that I look the valves are different sizes also. The Tiger has a smaller intake valve and larger exhaust (1mm on both). The Tiger has got shorter/later intake timing (7 deg) and earlier exhaust timing (9 deg). Plus the Tiger has more lift .2mm on the intake and 1.3mm on the exhaust.
Considering the Tiger has lower compression 11.6:1 / 12:1 I may get into trouble with piston/valve clearance mixing cams, valves, heads and pistons.
