Replacing torx head cam cap bolts - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!New BonnevilleOntario Tourism
Old 10-29-2007, 03:33 AM   #1 (permalink)
sidecar_ray's Avatar
Is there any reason why I couldn't replace the standard T30 torx head, cam cap bolts with hex head bolts? There is insufficient clearance between the frame & at least 3 bolts - 1 on the inlet & 2 for the exhaust - for the torque wrench etc that I have. I'm not much fussed on re-fitting the cams with a guess at the torque.
RayB
sidecar_ray is offline   Reply With Quote
Old 10-29-2007, 03:26 PM   #2 (permalink)
Favourite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
keep the torx
They are a much better head design, far less likely to strip out.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 10-30-2007, 05:07 AM   #3 (permalink)
There is no reason not to change them if you like, keep material grade the same. Can you cut down the torx bit to gain clearance?
Jhumphrey is offline   Reply With Quote
Old 10-30-2007, 06:51 PM   #4 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
I stripped 2 Torx bits while putting the Trident's motor back together.
Note that that's 2 *bits*, not fasteners. The bits were easily replaced for $3-4 at any auto shop. Finding the proper fasteners would've taken a lot longer & probably cost a lot more.
So, me, I'm stickin' with the Torx bolts.
Cheers,
-Kit
Old 11-01-2007, 12:22 AM   #5 (permalink)
I gave some further thought to this. I ended up just using the torx head bolts. I figured that, unless I could find out the specs of the orginal bolts - a different bolt may just cause materials problems - corrosion, different expansion rates etc.
It still doesn't change the fact that there are at least 3 cam cap bolts with restricted clearance. Triumph must have a special tool. Again.
RayB
Replacing CAM Cover Berta Twins Technical Talk 4 02-04-2007 10:08 PM
Replacing Cam Cover russd01 Twins Technical Talk 5 07-03-2006 08:05 AM
Cam chain and Tensioner - Does it ever need replacing adrianmol Tiger Workshop (archive) 5 06-20-2006 05:25 PM
replacing cam covers dseely Maintenance & Workshop Talk 1 02-18-2006 03:45 PM
replacing bolts on engines Classic, Vintage & Veteran 9 02-08-2005 07:00 PM
