Sprint St 2004 Datatool 3 Alarm Problem - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew BonnevilleSportbikeTrackGear
Old 10-17-2007, 04:07 AM   #1 (permalink)
Newbie
Favourite Bike: Sprint St 2004
Angry Sprint St 2004 Datatool 3 Alarm Problem
Hopefully someone can help me
I have just had a holiday touring in France up in the Alps. My first trip on the bike abroad.
On two occasions I had a problem with my Datatool System 3 supplied with the bike from new.
When I was buying petrol in a motorway services my alarm set and would not turn off.
It was pointed out to me that there was a large radio mast at the station that interferers with bike and car alarms.
On one occasion I had to push the bike about 0.5 miles away from the mast before the alarm could be turned off.
I tried to reset the alarm with the ignition key without any success. I did not now if I was remembering the code or the procedure correctly.
I would like to fit a switch under my seat so I can reconnect my ignition so I can ride away from any interference, then reset the alarm when away from any mast.
A BMW rider did this at the same time as I was having one of my problems.
On the second occasion I only had to push the bike behind a building and it reset.
Can you please provide a wiring diagram that will help me.
My other alternative is to remove the alarm. How do I return the wiring to standard if I go for this option.
I regret ever buying this alarm as it drive me mad when filling up etc.
I would be very grateful for any help you can give or can you point me in the right direction for finding info.
Thanks Doug
wilson_douglas is offline   Reply With Quote
Old 10-17-2007, 05:26 AM   #2 (permalink)
Favourite Bike: 2003 Sprint ST
Doug,
yes, big antenna masts can interfere with the datatool's remote frequency. I have a buddy of mine living near a big public television/radio network antenna mast and sure thing. pushing the remote wouldn't work, not even holding the remote against the alarm unit.
So, adding a switch beats the purpose of an alarm somehow, and IMHO would not be a good idea.
There is always the manual override mechanism via the key:
* initiate the alarm by switching the engine on - let the alarm go through the alarm cycle -use ear plugs
* When the alarm stops you have 5 seconds to initiate the key override by turning ignition off and on again. Then count the beeps until first number matches then switch off, etc. for the other numbers.
* if this happens again, move the bike behind an obstacle big enough that you don't have a line of sight with the antenna and preferably in metal (Faraday)
* when I park the bike, I check if i can see any big antennas, if I do, after switching off the engine, I try immediately to set the alarm, if the remote fails, I restart the engine I seek out another spot to park.. without pushing
hope this helps
SpiderTex is offline   Reply With Quote
Old 10-17-2007, 05:41 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
No masts
Hi Doug,
I also have the 2004 Sprint and the datatool S3 alarm.
I have not experienced any problems with mine I live about 1 km from a radio mast but maybe it's the wrong frequency.
I think Spidertex is on the right track.
Have you contacted datatool themselves via their website as they have a tech support section?
http://www.datatool.co.uk/
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 10-17-2007, 07:35 AM   #4 (permalink)
Datatool Alarm
Found this site which might help in an emergency, took a copy myself when I went touring in Europe this spring - I'd heard that the system might leave you in trouble if it goes on the blink.
http://www.sportstourer.org/index.ph...article&sid=40
Farnham1 is offline   Reply With Quote
Old 08-04-2009, 10:24 AM   #5 (permalink)
Stranded in France...
wilson -Douglas.
This is all happening to me now and in France! I am close to ripping out the alarm..... if I new how!
oats123 is offline   Reply With Quote
Datatool Alarm HELP paulel Hinckley Classic Triples 14 01-13-2012 05:24 PM
Datatool S4 Alarm nbolmer Gear & Gadgets 5 11-07-2007 10:17 AM
Datatool alarm patriot604 Twins Technical Talk 5 01-12-2007 02:18 AM
Datatool alarm wiring problem backwater Maintenance & Workshop Talk 0 09-07-2005 03:24 PM
Datatool Alarm bigD Tiger Chat 8 06-15-2004 07:49 AM
