Adventurer Fork Oil-whats up? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-10-2007, 06:51 AM   #1 (permalink)
Favourite Bike: 1999 T'Bird Sport
lovecuba's Avatar
Other Motorcycle: 2001 Sprint ST
Extra Motorcycle: 1977 T140
The Haynes Manual goes on about 20w/50 fork oil for the late model Adventurer. Can this be right? Went to my local oil distributor (Morris, British bike=British oil) and their book recomends 20wt oil. Their selection included 5, 10, 15 and 20wt oils on the shelf. I have gone for the 15wt oil (2 x 1 litre packs). Have I made the right decision and have I sufficient quantity?
lovecuba is offline   Reply With Quote
Old 10-10-2007, 10:32 AM   #2 (permalink)
grayghost's Avatar
I've never heard of a "multi-weight" oil for forks. You can't go wrong with what you are doing. The ride (dampening) will either be too stiff,right on, or too soft for your liking and you can adjust the oil weight accordingly.
Stiffer ride - go to a heavier weight oil
Softer ride - go to a "lighter" weight oil
" My bike pulls to the left......or the right....depending on what side of the road the Tim Hortons is on"
grayghost is offline   Reply With Quote
Old 10-11-2007, 11:38 PM   #3 (permalink)
Favourite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
Remember this
It is a Haynes manual, There is not any such thing as multigrade fork oil, chances are 99% is is a typical mistake haynes are famous for them. However I had a suzuki once that in the factory manual called for using 10w-40 in the forks. I think it was the 1981 GSX250 TSCC. I have also seen a friend that had a Kaw that specified 10w-40 car oil in the forks so it may be correct. if in doubt call your local dealer.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 10-12-2007, 10:24 AM   #4 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
My factory manual calls for 15W oil. Fill to 109mm below the top of the fork legs w/ forks completely compressed & springs out.
My Haynes agrees, right through VIN 43509. It specifies 10W20 at 126mm for VIN 43510 & up.
My factory manual was published well before VIN 43510.
10W20 is a real grade, though not necessarily easy to find. Repsol still makes it, AFAIK. Most people seem to substitute 10W, though some use 15W.
HTH,
-Kit
Whats this? And, why is it leaking oil? Mantooth04 Club Cafe' 8 05-15-2007 12:20 AM
Fork Oil - Increasing viscosity and oil level? NikosR Sprint Forum 9 04-21-2007 05:12 PM
Oil Choices (Whats yours?) Jam Twins Talk 23 05-22-2006 06:29 AM
speaking of oil...steamer fork oil amounts? flyintiger Tiger Workshop (archive) 2 02-22-2005 12:45 PM
Whats the best windscreen for an Adventurer? Msullivan Hinckley Classic Triples 10 07-15-2004 01:32 AM
