Dyno Jet vs Thruxton needles - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 10-05-2007, 04:31 AM   #1 (permalink)
Favourite Bike: Bonneville -01
Hi!
I´m planning to do the air box removal this winter and therefore I have to do some serious rejetting. I have read the Jenk´s jetting guide and a lot of other suggestions on jetting. But, my bike (-01 Bonnie) is Dyno Jetted by the previous owner.
My question is: does anybody know how the DJ needles compare to for instance Thruxton needles, that seem to be the most common? Do I need bigger or smaller jets if I keep the DJ needles? Or might it be better to go for the Thruxtons directly?
Thanks in advance
pelle is offline   Reply With Quote
Old 10-05-2007, 07:10 PM   #2 (permalink)
Favourite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
Not really sure but
When I narked my '02 I ran 138, 140 mains, 42 pilots and 1-1mm shim. and stock needles. I put my air box back in and now run the uni 128 mains 42 pilots and thrux needles, an 1 .5mm shim, I run D&Ds. I went back to the airbox because of the low end loss. I'm heavy and need this more than all top end on our twisty roads. to tight to go wot so you use low grunt a little more, I would call dynojet as their needles are diffrent from the factory tapers as are their jet numbers.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 10-09-2007, 11:45 AM   #3 (permalink)
Talked to a mechanic at the local Triumph-dealer today. He said that it was best to go back to stock or Thruxton needles, otherwise it would be really difficult to get it right. So I ordered some Thruxton needles and will go with that.
Old 10-09-2007, 12:55 PM   #4 (permalink)
Favourite Bike: 02 Bonneville
Other Motorcycle: 1972 Honda CL450 Scrambler
pelle...I installed the NARK a few months back and found the 150 Mains that came with the kit too large on my "02" with Thrux needles.
I wound up with 140's, and 42's for the pilots... 1-shim on the Thrux needles and 3 turns out. I have the Sprint pipes with 4" baffles installed in the adapter pipe.
Shorty
Different Strokes, for different folks.
2002 Red & Silver Bonneville
http://i22.photobucket.com/albums/b3...Bonneville.jpg
http://i22.photobucket.com/albums/b3...4/e0d93963.jpg
Shorty is offline   Reply With Quote
Dyno Jet Needles BonnieBob Twins Technical Talk 5 02-11-2008 09:52 PM
Dyno jet kit's for thruxton caspianthruxton Club Cafe' 6 09-22-2006 01:21 PM
Dynojet needles v. Thruxton needles stu Twins Technical Talk 6 08-17-2006 11:09 PM
Dyno Jet Looking for Bonnevilles vitabrew Twins Talk 3 07-16-2005 10:32 PM
dyno jet kit for the 1200??? Turin Daytona Deliberations 13 06-22-2005 01:24 PM
