rear wheel removal sprint rs 03 dual sided swingarm - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Motorcycle.comNew Bonneville
Old 10-03-2007, 10:47 AM   #1 (permalink)
Newbie
Favourite Bike: Triumph, Ducati
unclefz's Avatar
Other Motorcycle: Sold em all
Hi newbie needs to know how to remove / replace rear wheel on my Sprint RS 03 dual sided swingarm model. Can only find references to wheel removal on single sided machines.
Any (genuine) advice would be most welcome
Thanks
unclefz is offline   Reply With Quote
Old 10-04-2007, 11:31 AM   #2 (permalink)
Favourite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
It's pretty straight forward. a centerstand makes it a snap, otherwise you need to get the wheel off the ground.
1-loosen the chain adjuster nut/bolt and screw them toward the front of the bike.
l2-oosen the axle nut and push the wheel forward, and remove the chain.
3-remove the axle assembly, and the wheel drops. be careful to support the brake caliper.
4-remove the wheel. the sprocket carrier will most likely fall out, this will give you an opportunity to inspect the cush drive rubbers for dry rot.
5- keep a mental note, or take a picture of the spacers and bearings if you take apart the wheel.
takes about 5 minutes once you get it down.
good luck
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
chefjpd is offline   Reply With Quote
Old 10-04-2007, 01:27 PM   #3 (permalink)
Newbie
unclefz's Avatar
Hi
many thanks for the run down - the caliper and spacers were what I was thinking about when I orininally posted! Things generally fall out and its not always obvious which way they go back.
Thanks again for your help I'll try and get the wheel out this weekend as Ive burnt up the Bridgestone 014 and need to get it re shod.
Single-Sided Swingarm. Snake Sprint Forum 10 03-19-2007 05:07 PM
sprint exec rear wheel removal fraggle69 T3 Sport / Touring Forum 7 09-18-2006 04:43 PM
05/06 Sprint rear wheel removal bz919 Sprint Forum 1 07-15-2006 05:36 PM
Tip: good 46 mm socket (for rear-wheel nut on single-sided swingarms) Curmudgeon Maintenance & Workshop Talk 4 07-11-2006 03:54 AM
Rear wheel swingarm stand for T-bird Spooner Hinckley Classic Triples 6 09-09-2005 02:35 PM
