Pull choke out full for each cold start, and allow starter to fully turn engine over before releasing starter button. Once engine is running reduce your choke to half way, and allow engine to warm up. This should work every time.
questions:
1) what octane fuel do you use? lowest octane rating will give best fire.
2) have you removed sparkplugs? Are they wet or sooty? Try brushing them off with a brass fiber brush.
3) have you tried any fuel additives? You shouldn't need them.
4) when starting, do you twist your throttle? DON'T twist throttle until engine is running on it's own. You will blow your airbox, and flood your engine. Just pretend you have EFI when starting.
