Bonnie Shocks Advise - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleHonda Powersports Motorcycle.com Classifieds!Motorcycle.com
Old 09-29-2007, 12:31 AM   #1 (permalink)
Favourite Bike: '07 Triump Bonneville
RRunner's Avatar
Question Bonnie Shocks Advise
I have 600 miles on my '07 B'ville and ready for the dealer to stick it to me. The bike is riding great with the exception of the shocks. When I go over bumps, Rail Road xings or rough roads the bike is very, very stiff. I guess the shocks are set to factory specs. Does anyone know what can be done with the factory shocks to make the ride smother?
Any and all help would be appreciated.
RR
Roadrunner
RRunner is offline   Reply With Quote
Old 09-29-2007, 06:35 AM   #2 (permalink)
Favourite Bike: Suzuki DL650
uzidzit's Avatar
Other Motorcycle: 2002 bonneville
Extra Motorcycle: '80 Suzuki GS250 TSCC
Replace them.
The real problem with the suspension is the dampening. These come way way under dampened, go to the race tech sight and order a set of gold valves and a set of linear fork springs correct for your weight, (they can advise) and you will have a front end with adj. dampening, and the correct rate. Then go order a set of yss, ohlin, hagon, or progressive, or works shocks. The works are very good as are the yss. The hagons can be purchased with covers for the vintage look, these are adjustable for rebound dampening, and the works and yss for compression dampening as well. If you need to go cheap you can open the holes in the damper rods. and go to a heaver fork oil, this takes a lot of work and trial and error. There is really no help for the stock rears.
"Peter, It seems like you have been missing a lot of work recently, well Bob I wouldn't say that I've been missing it"
ENOUGH, go out and ride!
uzidzit is offline   Reply With Quote
Old 10-06-2007, 12:45 AM   #3 (permalink)
RRunner's Avatar
Much better
The dealer made a slight adjustment and I can live with it.
Roadrunner
Old 10-06-2007, 01:40 AM   #4 (permalink)
Ahhh..... You must have priced the alternatives!
(I can't live without a lot of things... until I see what they cost)
tamlin54 is offline   Reply With Quote
IKON SHOCKS FOR BONNIE! Brooksie Twins Technical Talk 22 03-01-2009 06:39 PM
'01 clutch chatter advise, any one who has had this fixed I need advise uzidzit Twins Technical Talk 9 01-08-2008 05:07 AM
Bonnie advise please bigred900 Twins Technical Talk 3 10-07-2006 08:08 PM
advise for a brand new black bonnie,, here's what i'm thinking jrussell6 Twins Talk 4 03-13-2006 02:55 PM
Thrux Rear Shocks vs. Bonnie Rear Shocks faffyface Twins Talk 1 01-24-2006 03:54 PM
